Replay's blue light is "burned out" - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 03-22-2012, 11:17 AM - Thread Starter
njj
njj's Avatar
My Replay is working just fine except the blue light doesn't show on the front of the unit any more. Is there a way to fix it? I'm not anxious to crack it open if there isn't an easy fix. The light just stopped working one day (like a light bulb that goes bad). The unit responds to the on/off and remote and works fine. Records fine, etc. I just can't tell if it's on or off until I turn on the TV.
njj is offline
post #2 of 4 Old 03-22-2012, 12:30 PM
adone36's Avatar
Liked: 37
The front board under the cover frequently has cold solder joints. Unplug the board and touch up the solder joints. or buy a clunker and scavenge a board from it.
Tony
adone36 is offline
post #3 of 4 Old 03-22-2012, 12:38 PM - Thread Starter
njj
njj's Avatar
Not knowing a lot about soldering, but if it was working for the last 10 years, why would it not have a good connection now?
njj is offline
post #4 of 4 Old 03-23-2012, 06:06 AM
ClearToLand's Avatar
Quoted: 27 Post(s)
Liked: 34
  1. Oxidation
  2. Vibration
  3. Burned out
  4. TBD...
Low Post Count <> Low Knowledge ergo High Post Count <> High Knowledge
ClearToLand's Picks For Best Answers to Common ReplayTV Questions
Remember, it's only TV...
ClearToLand is offline
Reply ReplayTV & Showstopper PVRs
