Farewell (for me) to ReplayTV - Page 2 - AVS Forum | Home Theater Discussions And Reviews
Old 05-19-2012, 01:24 PM
geobrick's Avatar
Originally Posted by adam1991 View Post
Why not XBox?
The new Slim models are quiet and bulletproof for this application, and you can find them for as little as $135 if you're careful.
Adam1991, I'm going to try the xbox as an extender. What did you mean about the "if you are careful" comment?
I see some on Craigslit locally that I'd try if I knew what to look for.
I'd look for a 360 slim with 4GB. Is there any thing else I need? If it is strictly for an extender, do I even need a controller? Do they have AV and HDMI outputs?
GB
geobrick is offline
Old 05-19-2012, 03:25 PM
adam1991's Avatar
Quoted: 40 Post(s)
Liked: 43
I mean, Amazon sometimes has them on sale plus giving an Amazon gift card on top of that.
You don't need anything more than the most basic 4GB, no-hard-drive Slim. Yes to HDMI and composite. You don't need a controller; all you need is a simple Media Center remote control. There's an XBox Universal Media Remote that works great; get the older white one, not the newer black one.
Mine are strictly extenders. They boot into MC, and that's that. With the remote, I can easily also use the DVD player. It's nice to have that.
adam1991 is offline
Old 05-20-2012, 02:29 PM
geobrick's Avatar
Thanks. I picked up a 4GB basic version at Fry's for $179 with a $20 gift card. (so $159 plus the tax at $179).
It works great so far. One more question. I'm using a Harmony remote. It seems the "media" command will turn on the xbox. What command will turn it off again? I want to have it turn off so that if it was last being used for live TV, I want to free up the tuner it was using. I try to avoid the power toggle commands when possible because if it was already off, it will turn it back on. Is there a command in the Media Center SE set to turn it off?
GB
geobrick is offline
Old 05-20-2012, 05:20 PM
adam1991's Avatar
Quoted: 40 Post(s)
Liked: 43
I use a Harmony 300; one of the buttons is for the XBox, and the power button simply toggles the XBox on and off.
I'm not sure. I don't use the event-based stuff on the Harmony.
Can you set something up to press "stop" on the extender? At least that will free up the tuner.
adam1991 is offline
Old 05-20-2012, 08:49 PM
geobrick's Avatar
I gave up trying to find a discrete off commend so I set it up to use the powertoggle for shutting it off. It's fine. The "media" command starts the xbox and if I assume it's still on when I select power on the remote, it will shut down the xbox.
I watch recorded TV 99% of the time anyway so it's not likely to ever hang up a channel on the tuner. I was just trying to set it up so it works consitantly. Power toggle can really mess things up when automating things.
GB
geobrick is offline
