Setting up IR Blaster - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 04-14-2012, 06:10 PM - Thread Starter
empyle's Avatar
OK, I feel pretty stupid right now. I have 4 Replay 4508s connected through WiRNS and running independent of DNNA. I (think I) have successfully added new IR Blaster codes to one of the Replays using WiRNS and shellcommands, etc. Now I am trying to configure the unit to use the IR Blaster and here I am stuck. I choose various kinds of Cable Boxes as the ANT/CATV input device, but never get the screen to setup the IR blaster.
Seems like I have done the hard part, but I can't get past this.
Can someone help?
-mitchell
empyle is offline
post #2 of 2 Old 04-15-2012, 09:46 AM - Thread Starter
empyle's Avatar
Never mind, I figured it out.
I had to go to Schedules Direct and add a new channel layout for Comcast Digital. That allowed the Replay to find a provider when I selected the digital cable box.
The rules are a little different when you are using WiRNS.
empyle is offline
Reply ReplayTV & Showstopper PVRs
