Fan Lock error message, but fan is working - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 04-15-2012, 04:15 PM - Thread Starter
pianoman41's Avatar
I recently got the 'Fan Locked' error message, but my fan does appear to be working. I also noticed that I no longer can view live video from either the coax input or the S-Video input (I just get a blank blue screen), but I can play back anything already recorded and the video is fine (so video input does not work, video out does). Do I still need to replace the fan?
-Matt
pianoman41 is offline
post #2 of 5 Old 04-16-2012, 11:25 AM
MrBobb's Avatar
Quoted: 165 Post(s)
Liked: 63
There maybe anther fan u can't see. Display problem says something already failed.
MrBobb is offline
post #3 of 5 Old 04-16-2012, 05:30 PM
sbwinter2's Avatar
This is the same problem I am having, but mine started with the no video and then the fan lock error came a few weeks later. I can hear the fan rev-ing faster and slower. I believe it is the power problem though and that is affecting the fan. Although I posted for some advice on this a while ago, not one person has responded. I can't be positive until I find a friend or someone who can test the power output for me (has the tools). Your problem may also be the same. There are instructions online on how to check and fix the power problem.
sbwinter2 is offline
post #4 of 5 Old 04-22-2012, 08:41 PM
erickotz's Avatar
Liked: 30
The fan is going to pulse the yellow wire (tach) for each revolution. If you have a scope or analog meter (not digital) you should check for this. If not, try swapping with a PC fan and see if problem is resolved. If not, you will likely have to trace it through the board - maybe look for a 0 ohm (1 black band) resistor nearby.
Of course, it's possible this is a software issue and a reset to defaults would resolve.
Quality Assurance Manager, Ceton Corporation
erickotz is offline
post #5 of 5 Old 05-15-2012, 05:32 AM - Thread Starter
pianoman41's Avatar
Thanks for the tip. I'll check that out.
-Matt
Reply ReplayTV & Showstopper PVRs
