Replaytv 5080 series Need Help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 05-03-2012, 05:11 PM - Thread Starter
wuz-upp's Avatar
Hello to all,
I am new to the forum, I have had my replaytv 5080 series for over 7 years. Recently I lost my signal due to my cable provider going digital. I was in the process of setting up my new video input/ outputs and I accidentally selected none on the output source. I now have nothing at all, I can't get to my menu page. Need help please.
Thanks in advance
wuz-upp is offline
post #2 of 3 Old 05-04-2012, 08:06 AM
ClearToLand's Avatar
Quoted: 26 Post(s)
Liked: 34
Originally Posted by wuz-upp View Post
...I was in the process of setting up my new video input/ outputs and I accidentally selected none on the output source. I now have nothing at all, I can't get to my menu page. Need help please...
AFAIK, "NONE" only affects the Progressive Output - you should still have RF (3 or 4) and Composite / S-Video.
Did you check them?
Low Post Count <> Low Knowledge ergo High Post Count <> High Knowledge
ClearToLand's Picks For Best Answers to Common ReplayTV Questions
Remember, it's only TV...
ClearToLand is offline
post #3 of 3 Old 05-05-2012, 10:47 AM - Thread Starter
wuz-upp's Avatar
Did you check them?
I tried the direct RF in-put to replay and RF output to tv, no help. I will try the composite/ S-video today.
I believe my internal tuner went bad about two years ago. I originally had the replay updates done through the phone jack and that stopped working. I then switched to the ethernet jack and it was working fine.
The possibility that my tuner is out might add to my problem. I realize that it looks like like my replay tv days are over, I would just like to see the saved recorded shows.
My question to all is, is there a way to regain my menu screen back.
wuz-upp is offline
Reply ReplayTV & Showstopper PVRs
