slow clock - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 05-08-2012, 02:24 PM - Thread Starter
david's Avatar
I'm connecting fine, getting schedule data, everything is working and recording, BUT my clock is about 4 minutes slow! So I'm missing the beginning of every show...
Is this something I can fix? Is it my unit, or the downloaded info? Anyone else seeing this?
david is offline
post #2 of 15 Old 05-08-2012, 02:34 PM - Thread Starter
david's Avatar
probably should mention it's a 3060 (upgraded long ago to a bigger drive) connecting via the original internal analog modem over a phone line.
david is offline
post #3 of 15 Old 05-10-2012, 06:53 PM
The Robman's Avatar
Quoted: 45 Post(s)
You might be able to fix it by dialing into the Perc server, details here:
http://planetreplay.com/phpBB2/viewtopic.php?t=16311
Have you ever installed the manual clock set patch? If so, it might be a good idea to install it. Install script below:
http://www.hifi-remote.com/forums/dl...&file_id=10872
Later, Rob
Select a link for questions on: Remotes, JP1, JP1 Forums
I prefer emails to PMs, my email is rob1 (at) rockabilly (dot) net
The Robman is offline
post #4 of 15 Old 05-11-2012, 09:29 PM
mlloyd's Avatar
Quoted: 33 Post(s)
It might be easier to use a disk image that already has the manual clock set patch installed:
for 2xxx:
http://rgb.cc/replaytv/images/replay...ualTimeSet.zip
for 3xxx / Showstopper:
Either way, you need to connect the Replay drive to a PC. It can be a lot easier to use a USB-to-IDE adapter. Then you can leave the drive in the Replay. Use the Replay as a power supply for the drive.
That's what I did with my 2020.
mlloyd is offline
post #5 of 15 Old 05-18-2012, 01:02 PM - Thread Starter
david's Avatar
Thanks Rob, that worked! The Replay lives on for another day.
david is offline
post #6 of 15 Old 05-18-2012, 05:52 PM
The Robman's Avatar
Quoted: 45 Post(s)
But that means you lose all your recorded shows, your programming, everything, and it takes longer than simply adding the patch.
Glad to hear it, enjoy!
Later, Rob
post #7 of 15 Old 06-16-2012, 08:21 AM
domonation's Avatar
robman, i need help
i got a rtv5080 from someone who said they hadn't used the unit for years, they had a lifetime subscription.
if i do not have a phone line and internet, can i use the unit to record shows manually like a vcr?
will i have problems with the clock, or can i set the clock manually with this model?
do you have any sites that can give me tips on this unit for a newbie?
i was told to take it to a friends house, hook it up to the internet to get update on time and guides, then i could use it anywhere else (place with no internet or phone line), once it had been updated, so that i could use it like a vcr, is that true?
domonation is offline
post #8 of 15 Old 06-16-2012, 05:23 PM
ClearToLand's Avatar
Quoted: 26 Post(s)
Liked: 34
Originally Posted by domonation View Post
robman, i need help
  1. if i do not have a phone line and internet, can i use the unit to record shows manually like a vcr?
  2. will i have problems with the clock, or can i set the clock manually with this model?
  3. do you have any sites that can give me tips on this unit for a newbie?
  4. i was told to take it to a friends house, hook it up to the internet to get update on time and guides, then i could use it anywhere else (place with no internet or phone line), once it had been updated, so that i could use it like a vcr, is that true?
  1. No. All units need to contact 'The Mothership' on a regular basis.
  2. The clock will drift; you cannot set it manually - only by contacting 'The Mothership'.
  3. Start out with the ReplayTV FAQ "Before You Ask...", STICKY'd at the top of the page.
  4. For 12 days (maybe). The clock will drift and the maximum amount of Guide Data it stores is 12 days. Once you run out of Guide Data, I'm not sure how long the unit will remain 'Activated' without a regular connection - I never tried it.
If you don't have a landline or internet connection and decide not to use it, please post your Zipcode so some other ReplayTV 'DieHard', like myself, can calculate shipping costs. wink.gif
Low Post Count <> Low Knowledge ergo High Post Count <> High Knowledge
ClearToLand's Picks For Best Answers to Common ReplayTV Questions
Remember, it's only TV...
ClearToLand is offline
post #9 of 15 Old 06-17-2012, 10:25 AM
gring40's Avatar
.... if i do not have a phone line and internet, can i use the unit to record shows manually like a VCR?
will i have problems with the clock, or can i set the clock manually with this model? ....
AFAIK, these make a lousy VCR because you can't schedule repeat recordings, even with a good clock. You have to schedule each recording individually, a major pain.
As noted, you will have clock issues; there is a patch for this, but even if you're technically up to it, it's doubtful it's worth it, as described above.
If you're willing to take it to a friend's house to download all setup and Guide data it will work fine when you bring it home, provided that you keep going back there to refresh the clock and Guide data, and that the clock doesn't drift too much between visits.
gring40 is offline
post #10 of 15 Old 06-17-2012, 01:33 PM
mlloyd's Avatar
Quoted: 33 Post(s)
When I was using a VCR a lot (before 1999, when Replays came out), about 95% of the recordings I made were manual, only 5% or so were timed.
mlloyd is offline
post #11 of 15 Old 06-17-2012, 04:55 PM
The Robman's Avatar
Quoted: 45 Post(s)
robman, i need help
You will need to take it somewhere with an internet or phone connection so you can get the channel guide downloaded. Eventually the channel guide will run out of shows if the unit is not connected, but it will keep the channel listing, so you should be able to use it like a VCR. And as this unit gives you the ability to rename your manual channels, you will at least know what has been recorded.
Later, Rob
post #12 of 15 Old 06-18-2012, 09:30 AM
domonation's Avatar
thanks robman,
robman - so if i take it somewhere with internet connection, i just hook it up and i can still get a channel guide (will this have show titles?). and then eventually i will lose guide, but it will keep channel listing (is this just the channel numbers?). how long will channel listing last before it disappears? how long will channel guide last? and will the clock eventually slow down in this model (rtv5080) and can i just manually reset the clock? sorry for all the questions, i am new to this thing, but thankyou for the answers - everyone
post #13 of 15 Old 06-19-2012, 07:52 AM
gring40's Avatar
... sorry for all the questions, i am new to this thing, but thank you for the answers everyone.
• So if i take it somewhere with internet connection, i just hook it up and i can still get a channel guide (will this have show titles?). > Yes & (Yes)
• and then eventually i will lose guide, but it will keep channel listing (is this just the channel numbers?). > Yes (+ channel ID)
• how long will channel Guide/listing last before it disappears? > maybe 2 weeks for your unit
• and will the clock eventually slow down in this model (rtv5080) > Yes, it will drift
• and can i just manually reset the clock? > No, needs a hack to do this
Maybe get it going at your friend's place and then you'll have a week or two to see how you like it. The Guide will disappear a day at a time, and you can search for shows to record off the Guide and learn the system. When the Guide runs out, you can try Manual recording. If you do like it, you can choose to get a phone line or Internet connection, or keep visiting your friend.
gring40 is offline
post #14 of 15 Old 06-19-2012, 01:13 PM
gring40's Avatar
Afterthought for domonation; the RTV has an NTSC tuner and composite inputs. Before you start, verify that your friend's video setup will give you something compatible with that, as well as your video input at home, in today's era of digital transmissions.
gring40 is offline
post #15 of 15 Old 06-21-2012, 09:48 PM
Quoted: 26 Post(s)
Liked: 34
SUBTITLE: 'Clock Patch' is Only for 3XXXs and Below... redface.gif
  1. Quote:
    • and can i just manually reset the clock? > No, needs a hack to do this ...
  2. Quote:
    ...will i have problems with the clock, or can i set the clock manually with this model? ....
    ...As noted, you will have clock issues; there is a patch for this, but even if you're technically up to it, it's doubtful it's worth it, as described above...
  3. Quote:
david, the OP, has a 3060. domonation, the 'Newbie / Hi-Jacker', has a 5080. AFAIK, the 'Clock Patch' only works on units up to the 3000 Series; never heard of one for the 4XXXs and certainly not for the 5XXXs.
Good afterthought about the 'Video Input' availability - something that some of us 'Old-Timers' just take for granted. wink.gif
Reply ReplayTV & Showstopper PVRs
