RTV gets stuck and then reboots - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 06-13-2012, 06:01 PM - Thread Starter
barmar's Avatar
Quoted: 18 Post(s)
Once or twice a week I'll be watching a recorded program, and my 5504 will get stuck, repeating the same from an a fraction of a second of audio over and over. It will do this for about a minute, and then finally reboot.
This sounds like it may be the disk corruption problem mentioned on Mikeyboy's site. But after it reboots, I can play the same show just fine, so I don't think it's a bad spot in that file. I also think it has happened when I was watching a show streaming from a networked RTV.
Does this sound like a power supply problem?
barmar is offline
post #2 of 6 Old 06-13-2012, 06:58 PM
adam1991's Avatar
Quoted: 40 Post(s)
Liked: 43
My guess is the hard disk. Intermittent problems on a failing hard drive are common.
adam1991 is offline
post #3 of 6 Old 06-17-2012, 02:53 PM
srfrdan's Avatar
that happens to me when im watching a recording show. i just watch a recorded show until the recording ones done and alls well. i think it hAS to do with heavy internet traffic screwing with the tiny chip these things have,smile.gif
srfrdan is offline
post #4 of 6 Old 07-26-2012, 08:17 PM - Thread Starter
barmar's Avatar
Quoted: 18 Post(s)
I haven't noticed it happening specifically when watching the show that's being recorded. But I think it's always when I'm watching and recording at the same time. Often the show I'm watching is being streamed from my other unit -- it might even be always, I haven't kept track.
But I was on vacation for a week and a half, and it doesn't look like it rebooted in the middle of any of the shows it recorded while I was away -- there are no short recordings during that time.
It's been doing it more and more often, so I'm going to get a new disk.
barmar is offline
post #5 of 6 Old 07-27-2012, 10:33 PM
ReplayLurker's Avatar
This typically happens when you view the Replay Guide of a remote RTV while the local RTV is recording and the remote RTV has more than something like 120 shows stored on it. So, if that's the case, you don't need a new hard drive, just fewer shows stored on your remote RTV.
ReplayLurker is offline
post #6 of 6 Old 07-29-2012, 03:11 AM - Thread Starter
barmar's Avatar
Quoted: 18 Post(s)
But that's not when the problem happens. It's always when a show is playing, I'm not even touching the remote. And the remote machine only has about 60 shows stored on it.
Anyway, I put the new disk in today, we'll see how it goes.
barmar is offline
Reply ReplayTV & Showstopper PVRs
