Webtv Keyboard typing wrong characters- SYM lock is apparently on. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 07-07-2012, 11:25 AM - Thread Starter
Steevo55's Avatar
I have used a webtv wireless keyboard with my replaytv units since the beginning.
They work great, btw. Excellent for search.
Anyway, I have gotten one into a weird mode. Somehow.
I haven't been able to get it to type normally.
I must have randomly pushed some buttons that set a symbol lock, num lock, or both.
If I type an r instead of an r I get R[ (two characters)
If I type an R instead of an R I get R{ (two characters)
If I type a 4 instead I get _$ (two characters)
symbol lock.
I haven't been able to figure out how to reset it.
Does anyone know? I took the batteries out and held down a key for a couple minutes. No help.
Steevo55 is offline
post #2 of 2 Old 07-07-2012, 06:49 PM - Thread Starter
Steevo55's Avatar
Originally Posted by satpro View Post
Try CTRL+SHIFT or CTRL+ALT, have you tryed with some fresh batteries, or try clearing the memory by jumping the positve to the negative bay at the oposite end to drain memory.
I have tried those keystrokes, and I did short out the battery compartment. It was brief, but it didn't make any difference.
Steevo55 is offline
Reply ReplayTV & Showstopper PVRs
