Issue getting Guide Update - AVS Forum | Home Theater Discussions And Reviews
Old 08-09-2012, 03:31 PM - Thread Starter
Skunkie's Avatar
Howdy,
I had to preform a factory reset lastnight to get my photo partition back, that went smooth, but now noticing when I do a 243 zones and a net connect it's not getting any guide data, even tried changing the settings in the setup and it's still not getting them, is this only my issue or is it others?
I'm on ethernet and not dialup.
Edit, I'm not going the wirns route right now either, I had that setup but since the guide data from leho was not free, I had to let the 7 day trial expire.
Skunkie is offline
Old 08-09-2012, 07:21 PM
srfrdan's Avatar
do the reset again and it should connect to replaytv server, i had a couplle replays that took a half hour to reboot even after one reset but after the next it took only a few minutes.---d ps make sure yure ports and firewalls are set in the router and computer
srfrdan is offline
Old 08-10-2012, 03:52 PM - Thread Starter
Skunkie's Avatar
I managed to do several more resets and forced it to do a couple of net connects and it's come back up with the guide, so guess that resolves this smile.gif
~Andrea~
Skunkie is offline
