View replay recordings in a web page? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-24-2012, 09:42 AM - Thread Starter
Tirebiter's Avatar
I have been searching for a few days for this.
I recall there are HTTP queries that can be sent to a Replay and get information, such as the current screen snapshot and the device description, etc.
Isn't there one to get a list of all the recorded shows channels?
Is there a list of all these requests somewhere?
Thanks in advance.
Tirebiter is offline
post #2 of 4 Old 08-24-2012, 01:02 PM
ReplayLurker's Avatar
You can find everything about "talking" to the RTVs at http://www.wirns.com/twiki. There used to be a software called something like Personal Replay Guide that allowed you to look at such things. However, you can find the ReplayPC project on SourceForge, which will allow you to "look" at your recorded shows...
ReplayLurker is offline
post #3 of 4 Old 08-25-2012, 11:39 AM
jlv
jlv's Avatar
The HTTP queries to the units returns raw data, not human consumable data.
The easy is to run one or move of WiRNS, DVArchive, or IVSMagic. All will give a web interface that lets you look up recorded shows. The first two will let you watch shows, too. WiRNS will let you do lots of other things.
jlv is offline
post #4 of 4 Old 08-25-2012, 12:20 PM
Yes, but there are several applications that will convert the guide snapshot into human readable form. ReplayPC has both the converter application as well as the guide snapshot fetching application. GuideParser is the original guide snapshot converter application, with GuideParser5 being the newer one for 5K guide snapshots...
Since the OP didn't specify what he wanted to do with the recorded show information, and didn't say anything about wanting a web interface, maybe he only wants a text formatted output of all of his recorded shows to do something with. I think only DVA gives you what it fetches from the RTVs in some file format that you can then do your own thing with. The other applications can only be used through their web interfaces (DVA not particularly using a web interface in the first place, except as a separate interface, but not its main interface)...
Reply ReplayTV & Showstopper PVRs
