Bridge router choices to replace 5xxx wired connection? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 09-01-2012, 12:10 PM - Thread Starter
gring40's Avatar
I'm using a Linksys WRT160N router for my home wireless network, and want to replace the RTV 5xxx Ethernet connection with wireless, just to get the Guide updates from DNNA; I'm not interested in content streaming. I'd like to know what bridge units people like these days, or what devices I might consider. Your thoughts?
gring40 is offline
post #2 of 11 Old 09-01-2012, 04:35 PM
Reden's Avatar
Quoted: 42 Post(s)
Liked: 61
use a cheap old router (Buffalo, Linksys, etc) that can run DD-WRT and use it in client mode.
If it's worth doing, it's worth doing in PERL!
Reden is offline
post #3 of 11 Old 09-02-2012, 10:34 AM
mlloyd's Avatar
Quoted: 34 Post(s)
That sounds good. Of course wired is better. For one thing, it's Simpler (and so more reliable).
mlloyd is offline
post #4 of 11 Old 09-02-2012, 05:08 PM
MrFussy's Avatar
That's the router (Buffalo) what I'm still using, although I'm using the stock WDS bridging mode. No problems for years that weren't of my own making.
3RTV over ethernet + DVA show server over buffalo wireless
MrFussy is offline
post #5 of 11 Old 09-04-2012, 05:13 PM - Thread Starter
gring40's Avatar
I have an old WRT54G, went to the DD-WRT site and am definitely daunted, not that it's much of a loss if I brick it. Maybe I'll consider a refurb WET610n, which Linksys says will work well, once I definitely rule out running an Ethernet cable (maybe 75').
gring40 is offline
post #6 of 11 Old 09-04-2012, 09:50 PM
Reden's Avatar
Quoted: 42 Post(s)
Liked: 61
Linksys WRT54G is really a family of routers. You need the version number that follows the model number to know what to do.
http://en.wikipedia.org/wiki/Linksys_WRT54G_series
Since you don't care about streaming, I definitely suggest going wireless and not running a 75' cable.
Robert
Reden is offline
post #7 of 11 Old 09-06-2012, 09:03 AM - Thread Starter
gring40's Avatar
Robert ... Thanks for the interesting link on WRT54G; mine is a ver 2, so would take 3rd party firmware if needed. Decided to get Linksys' refurb WET610N for under $38 (total, incl tech support FWIW), and agree that doing surgery on my walls for hard-wiring isn't worth it, since all I need now is a reliable connection for the Guide.
BTW, aside from other RTVs, what could a 5xxx stream to?
gring40 is offline
post #8 of 11 Old 09-08-2012, 10:24 AM
elorimer's Avatar
It could stream to an MVPMC. I do that all the time. And of course DVArchive.
In my limited experience using wireless gizmos to connect something with a wired port to my network, that for DHCP to work, WDS often works where client mode doesn't.
elorimer is offline
post #9 of 11 Old 09-09-2012, 06:49 AM - Thread Starter
gring40's Avatar
________________________________
That brings up the related question; is it better to use DHCP for converting a wired RTV to wireless, or a fixed IP address?
gring40 is offline
post #10 of 11 Old 09-09-2012, 12:47 PM
mjdbb1's Avatar
I use a Netgear WNHDE111 in bridge mode and it works great between 5xxx Replays. Even streaming is usually flawless. I also use a fixed IP.
mjdbb1 is offline
post #11 of 11 Old 09-11-2012, 07:30 AM - Thread Starter
gring40's Avatar
Good to know a fixed ip works, thanks. My bridge arrives today.
gring40 is offline
Reply ReplayTV & Showstopper PVRs
