RTV 50xx crashes, reboots when network cable is connected - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-12-2012, 07:51 PM - Thread Starter
jslaff's Avatar
This just started a day ago. Had the unit for close to 10 years. HD is 7 years old (upgraded). Not a days worth of trouble. No changes to my network architecture. Using Wirns, latest update.
RTV is set to a static IP. Unit was rebooting, getting to the Please Wait and then cycling off, and back to Please Wait. Unplugged AC and plugged back with same result.
When I unplugged the network cable from the switch (it shares a switch with a few other components), it rebooted, took a few minutes, and worked fine.
When I plugged the cable back in, it rebooted as before after a minute or two. Unplugged cable from switch, and all was well.
I then connected the RTV network cable directly into the router, bypassing the switch, but the rebooting started again. Tried a new cable, same thing.
Any ideas? Is the network chip in the unit shot? Thanks for the help.
jslaff is offline
post #2 of 3 Old 09-12-2012, 08:40 PM
ReplayLurker's Avatar
If you search this forum for this symptom, you will see that it is often caused by Winamp installed on something like a wireless device, like a cell phone or such...
ReplayLurker is offline
post #3 of 3 Old 09-12-2012, 08:43 PM - Thread Starter
jslaff's Avatar
Oh my god. I just got a Google Nexus tablet and did just that with Winamp. Thanks for the help!!
jslaff is offline
Reply ReplayTV & Showstopper PVRs
