Showstopper has stopped taking commands from remote control - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 09-18-2012, 07:26 PM - Thread Starter
rallenr's Avatar
Is it toast? The unit was working fine, then started to need multiple key presses to change channels and now accepts nothing from different remotes, all with fresh batteries. Any ideas appreciated! TIA.
rallenr is offline
post #2 of 6 Old 09-19-2012, 02:40 AM
Arvy's Avatar
Quoted: 93 Post(s)
Liked: 83
Did the IR plug fall out? Did you move the IR blaster on front of the cable box? Start simple then move on...
Arvy
Arvy is offline
post #3 of 6 Old 09-19-2012, 10:41 AM
gring40's Avatar
Details? What model RTV, and what model remote(s)?
gring40 is offline
post #4 of 6 Old 09-19-2012, 01:27 PM - Thread Starter
rallenr's Avatar
Panasonic Showstopper HS-2000, no IR Blaster in use.
Remote: One-for-All URC3021BG1 (good replacement for original, wish I could find more of them)
Does an IR Blaster emulate the sensor on behind the unit's front glass?
TIA.
rallenr is offline
post #5 of 6 Old 09-19-2012, 02:40 PM
Arvy's Avatar
Quoted: 93 Post(s)
Liked: 83
The IR blaster doesn't exactly emulate the sensor, it sends signals to the sensor telling the box what to do ... like "change to channel 402".
Arvy
Arvy is offline
post #6 of 6 Old 09-19-2012, 09:35 PM
gring40's Avatar
Showstopper remotes are notoriously troublesome; a layer of oil builds up on the button pads and needs to be cleaned with alcohol (done it many times now, but it's no fun to do the disassembly). The later remotes, like for the 5xxx series don't have this problem, and work well with the SS. Are you saying your universal remote still controls your other components properly?
gring40 is offline
Reply ReplayTV & Showstopper PVRs
