Missing Input Button? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 10-13-2012, 09:41 AM - Thread Starter
gring40's Avatar
On the old SS remote (bad as it was) there was an Input button, so I could toggle to the various RTV inputs. While much happier with the 5xxx-style remote, I miss that button, can't find an equivalent Menu option, and have to use my old (and barely functional) SS remote when I need to do this. :-(
Am I overlooking something?
gring40 is offline
post #2 of 8 Old 10-13-2012, 10:32 AM
ReplayLurker's Avatar
The 55xx remote has the Input button as does the 4xxx remote. You didn't state which model RTV you are trying to change inputs with the remote, but for the 50xx RTV you use 8-8-8-Zones to change inputs. You also can change inputs through the setup menu...
ReplayLurker is offline
post #3 of 8 Old 10-13-2012, 10:45 AM - Thread Starter
gring40's Avatar
Thanks. Still using a SS, but have a 5xxx unit on the shelf I plan to replace it with. I have several newer remotes; one has an Input button, and the other has a Commercial Advance button in that location, both of which which do nothing for the SS. Guess I need to install my 5xxx unit to get the input selection function back, right?
gring40 is offline
post #4 of 8 Old 10-13-2012, 11:01 AM
It depends on whether it is a 50xx or a 55xx. I forgot that the remote button is the same, it's just labeled differently on a 55xx remote. On a 50xx, it will toggle Commercial Advance, but on a 55xx it will change inputs...
It doesn't appear that the SS has these capabilities without the remote. There are several generic remotes which have the Input button on them, Philips having several models which will run the RTV...
post #5 of 8 Old 10-13-2012, 11:29 AM
mlloyd's Avatar
Quoted: 33 Post(s)
If you have one of the 5xxx Replays with "commercial advance", disabling that (with WiRNS) will make the button act as INPUT.
mlloyd is offline
post #6 of 8 Old 10-13-2012, 11:54 AM
Now you're making it complicated! Seems like a lot of trouble just to make the button on the remote work, especially since the 50xx doesn't need the Input button since it has two other ways to achieve the same thing. And, you can just purchase some generic remote which has the Input button. Doesn't seem worth the trouble to setup a separate computer to run WiRNS just to keep Commercial Advance disabled! Much less that if you had a 50xx, why would you want to turn off Commercial Advance just so you could use the CA button on the remote to change inputs?
But, it's good information, just not practical...
post #7 of 8 Old 10-13-2012, 02:17 PM - Thread Starter
gring40's Avatar
Thanks for all the info & discussion. Actually, I recently picked up both a 5504 and a 5040, but the fan's much louder on the latter, & I think I'd rather have a quiet fan than CA. Good to know I can select inputs either way.
gring40 is offline
post #8 of 8 Old 10-14-2012, 11:34 AM
mlloyd's Avatar
Quoted: 33 Post(s)
I'M not making it complicated. That's the way it is.
Also, the change in the CA/Input button was something I had read about before, and confirmed on an existing WiRNS/Replay system. In no way did I even suggest setting up WiRNS for this purpose only.
I remember noticing that this change didn't really help much. Selecting the input was still complex. When I need to do this, I would setup a fake device using that input, and disable all channels (prevents inappropriate automatic recordings). Then, I could select the input with a channel number in the proper range.
mlloyd is offline
Reply ReplayTV & Showstopper PVRs
