Fan Swap? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 10-18-2012, 10:03 AM - Thread Starter
gring40's Avatar
Now using a SS, I've picked up both a 5504 and a 5040. I'd like to use the latter (keep the others as spares), but the fan is noticeably louder, so I'm thinking of a swap. Are the fans interchangeable, and are there complications I should know about (I've done simple PC drive/memory/card replacements, but haven't opened an RTV)?
gring40 is offline
post #2 of 4 Old 10-18-2012, 07:52 PM
ReplayLurker's Avatar
You need to make ReplayTVUpgrade your friend! Check out this page! And, there are plenty of threads around with several ideas. Personally, I saw where someone simply plugged the 50xx's 12v fan wire into the 5 volt supply to make it quieter. And, there used to be several quiet fan upgrade kits, but they're probably harder to find now...
ReplayLurker is offline
post #3 of 4 Old 10-18-2012, 10:27 PM
SR94's Avatar
I had a 5040 that stopped functioning. I purchased a used/upgraded unit. The used unit had a non-working after-market fan. It was a breeze to have the two cases open, unscrew the fans from the chassis, disconnect the power wires, and put the working fan into the working unit.
SR94 is offline
post #4 of 4 Old 10-19-2012, 09:47 AM - Thread Starter
gring40's Avatar
Lurker ... Many thanks for the tip; I've now bookmarked RTVUpgrade as a valuable resource.
gring40 is offline
Reply ReplayTV & Showstopper PVRs
