New registration for Replay 5504 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 10-22-2012, 07:38 AM - Thread Starter
Bluewondertoo's Avatar
Is there any way to activate a brand new Replay 5504? It is fresh out of the box (which made reference to the 3-year free subscription). I have another, identical unit that is still in operation, so I am hoping to network the two devices. I do not really care if the new one gets programming. I just want to use it to play shows that I record with my existing unit.
Thanks, and sorry if this is a repeat question. I have been looking for the answer on the forum without success.
Bluewondertoo is offline
post #2 of 6 Old 10-22-2012, 09:15 AM
Reden's Avatar
Quoted: 42 Post(s)
Liked: 61
Did you try plugging it in? I should auto-activate on the first connect to the mothership.
If it's worth doing, it's worth doing in PERL!
Reden is offline
post #3 of 6 Old 10-22-2012, 11:34 AM - Thread Starter
Yes, I plugged it (power and ethernet) but it keeps telling me it cannot connect. I will get the exact language later today in case that gives a clue. The first time I tried, it automatically populated the IP settings. For the subsequent attempts, I had to fill them in manually.
I am using the same ethernet cable from my old Replay, which updated just fine when I moved the cable back to it. I thought maybe Replay would not activate a new subscription now (?). Or, perhaps it is good-old-fashioned user error.
post #4 of 6 Old 10-22-2012, 03:09 PM
srfrdan's Avatar
since uve got nothing to lose try a factory reset and start over again---d
srfrdan is offline
post #5 of 6 Old 10-22-2012, 09:01 PM
Reden's Avatar
Quoted: 42 Post(s)
Liked: 61
worst case, plug in the LaHo DNS address and it will at least get activated. I don't think you need an account, LaHo will activate and set the clock via the "Goodwill" program.
Robert
Reden is offline
post #6 of 6 Old 10-22-2012, 09:04 PM - Thread Starter
Thanks for the suggestions. Before resetting, I unplugged the new Replay and plugged it back in, and it then connected on its first try. Now, I just need to get the two units networked . . .
Reply ReplayTV & Showstopper PVRs
