Remote won't change channel.. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-06-2013, 01:15 PM - Thread Starter
elesko's Avatar
I moved my AV components.. Now my remote for replaytv won't change my directv channel. Forgot how to sync them back up.. Any body help? I am using a USB cable connection to directv..
elesko is offline
post #2 of 4 Old 01-07-2013, 12:54 PM
gring40's Avatar
Your RTV Manual says how to do it. My SS uses a serial cable, FWIW.
gring40 is offline
post #3 of 4 Old 01-08-2013, 05:20 AM
barmar's Avatar
Quoted: 18 Post(s)
I don't think ReplayTV can use USB. You have to use either IR Blaster or serial cable.
barmar is online now
post #4 of 4 Old 01-08-2013, 11:55 AM
gring40's Avatar
Elesko ... In a 2009 post, you had a ShowStopper, so if you still are using the SS remote, press the blue RTV button on the top to tell it you want to control your Replay, rather than the other (TV, CATV, VCR) options (or get a newer remote; mine died a long time ago).
gring40 is offline
Reply ReplayTV & Showstopper PVRs
