Replacement drive for 50xx unit. - AVS Forum
post #1 of 12 Old 02-03-2013, 07:47 AM - Thread Starter
bcochell's Avatar
Does anyone sell pre-formatted drives ready to install in a 50xx unit?
TIA.
bcochell is offline
post #2 of 12 Old 02-04-2013, 08:02 PM
guyzbliss's Avatar
eBay seems be an option. Check out this link: http://www.ebay.com/itm/320Gb-ReplayTv-Hard-Drive-Upgrade-Replacement-Replay-TV-5000-/321052328080?pt=US_DVRs_Hard_Drive_Recorders&hash=item4ac035c090
guyzbliss is offline
post #3 of 12 Old 02-06-2013, 02:23 PM
wtkflhn's Avatar
You can also try Weaknees.com. They sell them, too.
wtkflhn is offline
post #4 of 12 Old 02-08-2013, 11:43 PM
CopRock's Avatar
The prices on those drives is insane... It took me a while to get it right, but now I just buy a drive and RTV patch it myself, if I can do it most anyone should be able to...
CopRock is offline
post #5 of 12 Old 02-14-2013, 01:12 PM
adam1991's Avatar
Quoted: 17 Post(s)
Liked: 25
yeah, but it's the whole "FIND a suitable drive" that's getting to be impossible.
srfrdan likes this.
adam1991 is offline
post #6 of 12 Old 02-25-2013, 08:00 PM
srfrdan's Avatar
seagate db35.3 drives are best and plentiful--d
srfrdan is offline
post #7 of 12 Old 02-26-2013, 08:01 AM
replayrob's Avatar
Quoted: 92 Post(s)
Liked: 114
Seagate db35.5 series are SATA, Replays need old-school PATA drives.
"I say we take off and nuke the entire site from orbit. It's the only way to be sure...."
replayrob is online now
post #8 of 12 Old 02-26-2013, 01:33 PM
dstoffa's Avatar
and then PATA drives with friendly firmware....
Yes the Seagate DB35.3 ATA/100 drives are great, but I don't think they've been made in quite some time. I think at this stage of the game, it will be difficult to find a NEW drive that will work in a 5000/5500 series RTV. Used / Refurbed.... probably plentiful.
Cheers!
-Doug
dstoffa is offline
post #9 of 12 Old 02-27-2013, 06:44 AM
srfrdan's Avatar
but what i said is correct---d
srfrdan is offline
post #10 of 12 Old 02-27-2013, 06:54 AM
srfrdan's Avatar
Cheers!
-Doug
theyre
there all over ebay all sizes new and used and refurb---im using 10 750g i got last year in 8 replays and 2 in my xp comp that hasa 2tb sata hdd as well. there are many 100 120 and 160 hdd added on their home page as soon as i log on---d
srfrdan is offline
post #11 of 12 Old 02-27-2013, 07:13 AM
srfrdan's Avatar
i also had two replays with WD hdds in them thät i replaced with the 750s that were 80s. they work well i just wanted space to theme rec lots of movies. model wd8000bb-55jkao
srfrdan is offline
post #12 of 12 Old 02-27-2013, 07:28 AM
srfrdan's Avatar
its a good idea, at first i used weaknees but its well worth and fun to learn to do it yourself. also u still have to net connect to get the latest os and if rtv mothership goes down ull be learning anyway---d
srfrdan is offline
Reply ReplayTV & Showstopper PVRs
User Tag List
