ivsmagic not updating to 1.0.0.0 - AVS Forum | Home Theater Discussions And Reviews
Old 07-19-2013, 11:16 AM - Thread Starter
srfrdan's Avatar
hi, after a clean install ivsm does not update to the final version . the updater fails and disconnects. can someone check to see if their updater works so i know if its my comupter or the source thats at fault. thax in advance ---d:confused:
srfrdan is offline
Old 07-21-2013, 10:05 PM
Whitebar's Avatar
It is not you. IVSM update is looking for the manifest here: http://www.replaytvupgrade.com/ivsmagicbeta/CVS/manifiest.xml which is not present.
ClearToLand likes this.
Whitebar is offline
Old 07-22-2013, 03:45 PM - Thread Starter
srfrdan's Avatar
thanx much for the help- i was beginning to feel unloved---yuk-yuk--ivsm seems to work ok anyhow---d
srfrdan is offline
Old 08-04-2013, 01:44 PM
pwreimers's Avatar
The link is broken. any update? My IVSMagic is not working for show sharing...
pwreimers is offline
Old 08-10-2013, 05:13 PM - Thread Starter
srfrdan's Avatar
success!!!-- appears to work at least it says 1.0.0.0,thank u---d-- open the zip file whose link i copied and pasted here for people whose glasses are painted on like me and simply drag the new file and drop it into the program files and click yes to all and ur done, piece o pie-- http://67.41.76.186/cgi-bin/viewcvs.cgi/IVSMagic/IVSMagic.zip?tarball=1
srfrdan is offline
