Replay TV and Slingbox - AVS Forum | Home Theater Discussions And Reviews
Old 07-19-2013, 08:57 PM - Thread Starter
rplenty's Avatar
For years my Replay and Slingbox have worked happily together. Recently Slingbox must have changed the codes because my remote has channel guide grayed out and replay guide bring you to the channel guide. This is on PC and Ipad versions. Anyone having the same problem or know a solution beyond bugging Sling?
rplenty is offline
Old 07-20-2013, 08:55 AM
jweinel's Avatar
I use ReplayTV 5040's with four different Slingbox models from "Classic" to latest 350 and both Android and Web-based Slingplayers. The old stand-alone PC Slingplayer is not compatible with the new 350 and 500 model Slingboxes but still works with earlier models.
You should provide your model specifics for all devices to help with a solution.
Jim
Jim
jweinel is offline
Old 07-20-2013, 10:00 AM - Thread Starter
rplenty's Avatar
I have the slingbox solo model and 5040 replay's
rplenty is offline
Old 07-20-2013, 04:52 PM
Kuczynski's Avatar
I've a slingbox solo and a replay 504x. The Slingbox software on my laptop works fine. Granted when I first got the slingbox 1.5 years ago, I needed to add fixes for the 0616 device file for it to correctly handle all of the buttons on the remote correctly.
Kuczynski is offline
Old 07-20-2013, 05:15 PM
Kuczynski's Avatar
If anything, I'm a little surprised that your slingboxes worked earlier without any fixes to the PC software.
Old 07-21-2013, 02:07 AM
Kuczynski's Avatar
Here's the two files that get put in the \Program Files\Sling Media\SlingPlayer\SBAV directory that fixes the replay remote for Slingplayer.
SBAV.zip 1k .zip file
File Type: zip SBAV.zip (709 Bytes, 21 views)
