Replay TV Lifetime Supscriptions questions - AVS Forum | Home Theater Discussions And Reviews
Old 08-18-2013, 07:45 PM - Thread Starter
duckland23's Avatar
I was wondering all the replay tv pvr boxes and now currently a lifetime subscription . Im wanting to buy a boxwith a lifetime subscription so I don't have to pay direct tv its 20.00 a month for there genie box , Not that its not a bad idea but Im trying to save some money right now .The less I spend On fee's The better off I am . Im paying like 40.00 a month under the promo pricing for 12 months . But after that its back to standard pricing .I want to record shows for my wife if she miss them them when she's at work for some reason . Can anyone point out if the current boxes are now lifetime subscription . I thought I read on the internet that all the replay boxes are now lifetime until otherwise .
duckland23 is offline
Old 08-19-2013, 12:04 AM
Arvy's Avatar
Quoted: 93 Post(s)
Liked: 83
All ReplayTV boxes are lifetime after connecting to the mothership and being updated. The first connection to download program guide info, set the clock, etc. (after late July 2012) will make any box lifetime subscribed.
duckland23 likes this.
Arvy
Arvy is offline
Old 08-19-2013, 02:18 PM - Thread Starter
duckland23's Avatar
So If I buy one Im good to go . Im thinking of buying a used one from a guy off craigslist this week .
Old 08-19-2013, 05:15 PM
Arvy's Avatar
Quoted: 93 Post(s)
Liked: 83
If the box you buy works, the lifetime sub will, too.
Arvy
Arvy is offline
Old 08-19-2013, 05:31 PM - Thread Starter
duckland23's Avatar
thanks .
Old 08-20-2013, 02:03 PM - Thread Starter
duckland23's Avatar
I bought a used one from ebay last night . I got the replay 5060 model with the box for 30.00 plus shipping .Im hoping to use it with directv when I get it fior recording my wifes shows . Im going to get two of them In the future . but for now the one will do .Im under the impression that the Directv D12 boxes don't have ir blaster codes . But I was told to ad them .My next best thing is a d10-100 box .
Old 08-26-2013, 08:08 PM - Thread Starter
duckland23's Avatar
It seams to work fine a load the program guide fine . But how do I get it to change the channels when I click on what im watching from the replay box .
Old 08-27-2013, 09:33 AM
rlichtefeld's Avatar
You will need to use an IR Blaster to have the ReplayTV control the digital tuner box. If you didn't get any in the box with the ReplayTV, you can find them pretty cheap on eBay. They plug into the back of the ReplayTV and stick onto the front of the digital tuner box.
Thanks: ijprest, waynethedvrguy, Remmer99, hdonzis, gduprey, LeeThompson, j.m., archdog99, FlipFlop, The Dreamer, chriv and all the other Replay Hackers out there.
rlichtefeld is offline
Old 08-27-2013, 01:08 PM - Thread Starter
duckland23's Avatar
I have one , but Im unsure how to program it .
Old 08-27-2013, 04:15 PM
srfrdan's Avatar
all the modern dtv boxes use the new remote, the same one, so u need to program that into the rtv urself with ur computer. theres many threads on the topic and a few methods---d😊
srfrdan is offline
Old 08-28-2013, 07:01 PM - Thread Starter
duckland23's Avatar
How do you program it from your computer ?. You have some links on how to do it . Im lost on where to start . Im am running wisn now . I heard that someone had installed the codes from there . The picture software wont work under windows 8 .
Old 08-28-2013, 08:40 PM
dstoffa's Avatar
Quoted: 56 Post(s)
Liked: 24
http://webpages.charter.net/mamvc/
Your RTV does not have the codes to control your DTV box. You need to add them yourself. That page demonstrates one way. Good luck.
dstoffa is offline
Old 08-30-2013, 02:46 PM
srfrdan's Avatar
this is the method i like to use because im not computer savy. i find that u can use the replaytv photo app to put the ir codes onto the rtv hdd instead of dvarchive in the first step ---much easier the ir file folder goes into the photo folder folder and are instantly uploaded to the rtv--u need to put the ir code file and the ir codes raw file in the same folder as the c1000rid file, theyre found in the shellcmds file and those three get uploaded to the rtv by dva or as i do using the photo app---d
srfrdan is offline
Old 02-14-2014, 04:26 PM
kellylee's Avatar
So what if it says new?  or reconditioned?  Would the lifetime still be valid?
kellylee is offline
Old 02-14-2014, 05:28 PM
Reden's Avatar
Quoted: 42 Post(s)
Liked: 61
Lifetime or monthly is a moot point now.... All units are effectively lifetime as DNNA is not charging for a subscription.
Robert
If it's worth doing, it's worth doing in PERL!
Reden is offline
Old 02-14-2014, 05:35 PM
kellylee's Avatar
Thank you. I was afraid if it was never activated, the lifetime subscription wouldn't apply.
kellylee is offline
