replay tv digital 5040 not compatible with comcast - AVS Forum | Home Theater Discussions And Reviews
Old 08-24-2013, 12:41 PM - Thread Starter
bez22's Avatar
I plugged a cable from the wall to the 5040 and from the 5040 into a digital tv, message = no video signal. Comcast says that the DVR must be registered and they only register TiVo and their own. Replay dead?
bez22 is offline
Old 08-24-2013, 04:55 PM
jweinel's Avatar
You will get better help if you provide some more details.
1. Wall to 5040 - assume this is coax cable from Comcast, no box (keep in mind ReplayTv will only handle analog signal on coax).
2. 5040 to digital TV - is this coax or red/white/yellow cable or red/green/blue cable?
3. Has ReplayTv been configured for your local Comcast analog channel lineup?
Jim
jweinel is offline
Old 08-25-2013, 08:24 AM
jonwz's Avatar
My mom has comcast and I have her on a replaytv. Recently Comcast turned off ALL analog signal in her area.. Each analog TV needs a comcast provided converter box. The ReplayTV is analog. It needs a converter box as well, and the appropriate code enabled in the ReplayTV's setup.
If you still have an analog TV see if that can pick up any stations from Comcast.
When comcast talks about registering a Tivo, I think they are referring to a Tivo with Cablecard. In that configuration, you don't need the comcast converter box.
jonwz is offline
Old 08-26-2013, 11:23 PM
Reden's Avatar
Quoted: 42 Post(s)
Liked: 61
You'll need to go wall -> cable box -> replaytv. The ReplayTV can control some cable boxes via a IR blaster.
If it's worth doing, it's worth doing in PERL!
Reden is offline
Old 08-27-2013, 04:29 PM
srfrdan's Avatar
comcast gives dta boxes that output rf analog signals. i run four replays off them. u need to update the ir codes in the rtv.. theres many threads on that smile.gif ---d
srfrdan is offline
