IR Blaster how to program it for 5060 replay Help . - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-26-2013, 06:13 PM - Thread Starter
duckland23's Avatar
Hi guys I got my directv today and it updated the program guide ok . I wondering how it can change the channels .To to hook it up and so forth , Please help me if you can .
duckland23 is offline
post #2 of 4 Old 08-26-2013, 09:41 PM - Thread Starter
duckland23's Avatar
was wondering if when you change channels in replay and the channel said 265 and so forth and your watching HBO lets say channel 507 but the channel you selected for 265 stays on hbo channel 507 is the IR Blaster working to change the channels . Let me know .
post #3 of 4 Old 08-27-2013, 03:36 PM
srfrdan's Avatar
u need to find the cable box codes in ur replay , if ur box is not listed u need to install them if available---d
srfrdan is offline
post #4 of 4 Old 08-27-2013, 05:52 PM - Thread Starter
duckland23's Avatar
where do you place the IR sensor on the directv box . You place it over the box sensor for directv right .
Reply ReplayTV & Showstopper PVRs
