Channel Guide Has Wrong Time Zone for at least One Channel - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 09-11-2013, 11:51 AM - Thread Starter
Sleigher1's Avatar
So I'm not getting It's Always Sunny in Philadelphia or the League because FX switched these shows to FXX (channel 394 where I live).
The channel guide is showing that the shows are starting three hours earlier than they are.
I can record manually but who wants to do that?
I checked my channel guide from the cable (Time Warner) and it is showing the correct time zone.
Is there anyone or anyplace that I can call to alert them to the miscue?
I love my ReplayTV I have three of them.
Thanks in advance.
P
Sleigher1 is offline
post #2 of 5 Old 09-12-2013, 05:26 PM
srfrdan's Avatar
if u use wirns to put ur guide in and schedules direct to to fill wirns then go to schedules direct .com and let them know
srfrdan is offline
post #3 of 5 Old 09-12-2013, 11:33 PM
Reden's Avatar
Quoted: 42 Post(s)
Liked: 61
Usually there are East and West versions of satellite channels.
Either Tribune is giving guide data for the wrong one, or your cable company is pointing to the wrong one. Both have been known to happen.
If you use SD you can submit a lineup report to have it addressed. If not, you can just wait for someone to figure things out.
Robert
If it's worth doing, it's worth doing in PERL!
Reden is offline
post #4 of 5 Old 09-13-2013, 05:00 PM - Thread Starter
Sleigher1's Avatar
Thanks for the replies.
What is SD?
P
post #5 of 5 Old 09-13-2013, 05:30 PM
jweinel's Avatar
Schedules Direct, the alternate supplier of guide data for ReplayTv owners using WiRNS (Windows Replay Network Server).
Jim
jweinel is offline
Reply ReplayTV & Showstopper PVRs
