ReplayTV Remote Setup Code for AKAI brand TV? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-26-2002, 08:43 PM - Thread Starter
crayf's Avatar
I have an AKAI model CFT2791 TV in the back room that doesn't respond to the Replay Remote using any of the AKAI codes listed.
Does anyone have an AKAI brand TV they're using with their ReplayTV and are using a Remote Setup Code other than the 3 listed in the manual (0030, 0098, and 0591)?
any help would be appreciated...
C. Ray F
crayf is offline
post #2 of 3 Old 12-27-2002, 07:30 AM
terrysmirl's Avatar
Try the Samsung codes. As far as I know, Akai TV's are made by Samsung and rebadged with the Akai logo. I have an Akai CFT2790 and the first Samsung code listed in the manual worked perfectly for me. Good luck!
terrysmirl is offline
post #3 of 3 Old 12-27-2002, 10:14 AM - Thread Starter
crayf's Avatar
We'll I'll be... go figure...
That did it. Sure enough, the first Samsung code, 0060 worked...
One more remote I can now through into the remote drawer.
A heart filled thanks for your help terrysmirl! :)
cheers,
crayf is offline
Closed Thread ReplayTV & Showstopper PVRs
