"No Guide Information is Available" Using WiRNS on 5500 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 08-16-2015, 02:31 PM - Thread Starter
Bobcrane's Avatar
My 2 Replays have been on WiRNS/MCXML for many years.
I recently had to update the guide pull (M$ switched providers). I've had a handful of successful updates since the switch.
Last week after the latest update all guide data (including channels) is gone and we're left with the message "No Guide Information is Available." We're told to then check inputs.
I've confirmed WiRNS is up, the XML file appears to have data, and the Replay's input is set to the WiRNS source. WHen I force a net connect it sits for a LONG time on setting clock, eventually moves past that, then flies through the other stages and loads nothing.
Anyone seen this before?
Any ideas?
In-Law's Replay is setup the same way and they are having the identical issue. Both houses worked fine at one time.
Bob
Bobcrane is offline
post #2 of 2 Old 03-08-2016, 02:47 PM
dontcareavs's Avatar
As I understand it Microsoft shut down their legacy guide service. You need ZAP2XML (free) or a paid guide provider.
-eslave
dontcareavs is offline
Reply ReplayTV & Showstopper PVRs
