Delete Guide on Sonic 5060 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 02-09-2016, 11:59 AM - Thread Starter
eagleyed's Avatar
Question Delete Guide on Sonic 5060
I have a Sonic 5060 and want to delete the current guide but don't know how to do this. The reason I need to delete the guide is because I moved. If the only way to do this is reset the unit I don't know how to do that either.
eagleyed is offline
post #2 of 4 Old 02-09-2016, 12:13 PM
The Robman's Avatar
Quoted: 45 Post(s)
I assume you have already reprogrammed SD or LaHo to reflect the correct guide at your new location?
To clear the channel guide, go to a blank screen (ie, one where you could enter channel numbers) and enter 243 then press the Replay Zones button on the remote. You will now see a menu screen where one of the options is to clear the channel guide.
Later, Rob
Select a link for questions on: Remotes, JP1, JP1 Forums
I prefer emails to PMs, my email is rob1 (at) rockabilly (dot) net
The Robman is offline
post #3 of 4 Old 02-09-2016, 12:23 PM
barmar's Avatar
Quoted: 18 Post(s)
I don't think you need to delete the guide when you move. Just select a new lineup in Setup, and when it connects to the server it will replace the guide data.
barmar is offline
post #4 of 4 Old 02-09-2016, 03:00 PM
dstoffa's Avatar
Quoted: 71 Post(s)
Liked: 27
If you moved to a new location with different channels, then you will need to select a new TV provider, and that means you will update your lineups in WiRNS or PercData / LaHo.
You will then go to setup on your RTV, change the zip code to something you've never used before, and have the RTV fetch a new lineup from WiRNS or PercData / LaHo.
DNNA will no longer provide you with a "new guide"
dstoffa is offline
Reply ReplayTV & Showstopper PVRs
