I need help from you guys - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 10-24-2016, 02:31 PM - Thread Starter
shar2649's Avatar
Quoted: 12 Post(s)
Running 5 5000 series Replays with 3 PC's in 5 different locations. Connections are wired and not wireless. Using Netgear router N041 with Netgear XE104's. All was well until the PC acting as server died...it was .107 and so I reconfigured the .100 PC (the dead one) to rename it .107 and now I cannot get WIRNS to function. I can see all the machines on the Replay display but they will not update. I have a Surfboard SB6121 running with the other stuff. I have played around moving the ethernet cables but nothing is working. I need to ask for specific advice, i.e. a blue cable goes here, a black one goes here, gray here, etc. I have all these things but right now I am an old hopelessly lost woman pleading for your assistance. Thanks in advance for ANYTHING you can do to help.
shar2649 is offline
post #2 of 4 Old 10-25-2016, 09:15 AM
mlloyd's Avatar
Quoted: 34 Post(s)
Your new computer (running WiRNS) has the same IP but a different hardware (MAC) address. This may confuse one or more of your network switches. Reset then (remove power for a second and reconnect it). Reset your router too. I have had that (resetting switches) fix such problems (things not working after a change).
If you can download the guide (Administration / Update Guide), your cable modem (I have the same model) is probably not the problem.
mlloyd is offline
post #3 of 4 Old 10-25-2016, 04:09 PM - Thread Starter
shar2649's Avatar
Quoted: 12 Post(s)
Can you kindly tell me how to find the MAC address? Thanks. And is it possible for me to email you?
shar2649 is offline
post #4 of 4 Old 10-25-2016, 06:46 PM
mlloyd's Avatar
Quoted: 34 Post(s)
Your router maintains various tables, including one that lists all IP addresses given out and the associated MAC addresses. A MAC address looks like 12:3B:FF:6C:72:81. However, you don't need this information just to reset a switch, as I was talking about.
As to email, this forum allows private messages. Would that be OK? To send a private message, click on the poster's name.
mlloyd is offline
Reply ReplayTV & Showstopper PVRs
