Replay channel 281 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 11-12-2016, 08:32 PM - Thread Starter
RileySmith's Avatar
Replay channel 281
I have a replay 5040 and a 5080 and I use perc data to get my guides, I use a translater to send channel selection to my directv box and this works well. but I have noticed on both units that I can't go to channel 281 which is the vel (car repair) channel. if it's on a (say 3)channel and I go to the guide and select 281 it acts like it changes channel but is still on the same channel. any idea what I can do or is there a way to fix this. like I said I use perc data and this channel is selected.
Is anyone else having this problem?
RileySmith is offline
post #2 of 4 Old 11-14-2016, 08:48 AM
barmar's Avatar
Quoted: 18 Post(s)
Can you go to the channel using the cable box's remote?
barmar is offline
post #3 of 4 Old 11-16-2016, 08:05 PM - Thread Starter
RileySmith's Avatar
I didn't think of that since I get the channel on my directv genie, so when I try to go there on my d700 box it says channel not available. I should get the same channels on both boxes right. I'll give directv a call and see what they say.
thanks again for the response.
post #4 of 4 Old 11-16-2016, 08:49 PM - Thread Starter
RileySmith's Avatar
well direct tv said that my d12-500 box can't get the channel because it's an HD channel. so I guess that's the reason.
Reply ReplayTV & Showstopper PVRs
