More New Replay 5000 Software Toys! - Page 6 - AVS Forum | Home Theater Discussions And Reviews
Old 11-30-2003, 08:41 PM
icecow's Avatar
Originally posted by bunsen
This is my first attempt at using RTConvert, and I keep getting this error:
audio buffer overflow: len=66809
Here are the audio specs for my source file:
Audio : 10.12 MB, 224 Kbps, 48000 Hz, 2 channels, 0x51 = Mpeg-1 audio Layer 2 [0xc0], Supported
What's wrong?
This is an old thread.
There is an updated version of the rtvTools you are trying to use including rtvConvert here:
http://www.avsforum.com/avs-vb/showt...hreadid=314017
Try downloading the newer version of the software.
If you still have problems, ask about them in the newer thread listed above.
Welcome to AVS Forums.
(No I don't work here)
cow
icecow is offline
Old 11-30-2003, 09:09 PM
bunsen's Avatar
Thanks. I got to this thread from the ReplayFAQ.com main page.
bunsen is offline
Old 12-06-2003, 06:23 PM
dwwillia's Avatar
I have read this thread and decided to try extracting some programs from my Showstopper using the extract_rtv program and attempt to play them back through my 5040 using the DVArchive tool. I can get the mpg file into DVArchive and I can play the file on my PC, but it does not show up in the guide on the 5040. I can see other programs in DVArchive in the 5040's guide. Does anyone have any ideas why I can not see the program in the 5040's Guide?
dwwillia is offline
Old 12-06-2003, 07:36 PM
icecow's Avatar
There is a more current thread on this topic here:
http://www.avsforum.com/avs-vb/show...threadid=314017
Better to reply to this post there.
Did you 'import' the shows into DVA?
cow
icecow is offline
Old 12-07-2003, 03:02 PM
dwwillia's Avatar
icecow
Your link to the more current thread comes back page not found???
and yes I imported the show into DVA
dwwillia is offline
Old 12-07-2003, 04:27 PM
qtv
qtv's Avatar
I believe icecow was trying to refer you to the following thread.
ReplayTV 5K Tools (Revision 4)
qtv is offline
