DVA won't delete - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 11-25-2003, 01:59 PM - Thread Starter
PVRick's Avatar
DVArchive won't delete a show from the RTV after downloading/exporting/moving it; the log shows (something to the effect of) 'unhandled request'.
I seem to be using the right version of Java. My 2 RTVs (both exhibit the same behavior) are both on 5.1 software. The Linksys router seems to be set up right - shows stream among the RTVs and DVA just fine. Download throttle currently set at 256 but changing or defaulting didn't make a diff.
BTW when deleting one show directly from the DVA guide, it works.
Help? :confused:
PVRick is offline
Closed Thread ReplayTV & Showstopper PVRs
