ReplayTV with Dishnet UHF Remotes - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 12-01-2000, 01:55 PM - Thread Starter
kbright's Avatar
I have just bought the Panasonic PV-HS2000 and I am afraid I will have to return it. I have 2 of the high end JVC HM-DSR100U DishNetwork receivers with integrated MPEG2 D-VHS VCR.
As with the other top of the line Receiver Only units from Dishnetwork, the remote control communicates with the receiver via UHF which is great when using the remote from other rooms.
However it does not seem to be able to receive IR signals at all. It also does not have a serial interface.
Does anyone have any ideas that would let get by this problem. Is there another Panasonic model coming that might address this? Or a black box approach?
kbright is offline
post #2 of 11 Old 12-01-2000, 03:19 PM
DrJoe's Avatar
Do your homework!
LOL
This has been addressed several times...
Do a subject search on Dishnet, UHF, and/or remotes -- and the relevant threads shouldn't be hard.
If I recall correctly, there is an IR/UHF adaptor you can buy, and a hardware fix if you want to open up the receiver.
Ciao
Joe
[This message has been edited by DrJoe (edited 12-01-2000).]
Home Page (click to enter)
RCA Television Service Information (DTV306/7 and ITC222)
DrJoe is offline
post #3 of 11 Old 12-01-2000, 04:06 PM
PRMan's Avatar
There is a solution listed in the FAQ, although I'm told it's not trivial.
PRMan
PRMan is offline
post #4 of 11 Old 12-01-2000, 04:55 PM
Zelda Nation's Avatar
Originally posted by DrJoe:
Do your homework!
LOL
Lighten up, Doc. If you looked at the number of posts he's made, you'll see this was FIRST time he's proposed a question. Perhaps (and most likely) he didn't know he could [b]do[b/] a search here on the site or what he should do a search for.
Let's not run off the new people.
Not quite so new,
Zelda Nation
-Zelda Nation
"You've got your Opinion in my chocolate"
Zelda Nation is offline
post #5 of 11 Old 12-04-2000, 10:30 AM
DrJoe's Avatar
Originally posted by Zelda Nation:
Lighten up, Doc.
Zelda Nation
Perhaps you don't know what the expression "LOL" means...
I was trying to facetious!
"LOL" means "laughing out loud"...
Relax
Joe
DrJoe is offline
post #6 of 11 Old 12-04-2000, 11:30 AM
hastypete's Avatar
There is a quick hack fix. Just run a wire from the IR-blaster output on the replay box directly to the UHF antenna. This works since the strong DC signals overwhelm the UHF circuitry.
DISCLAIMER: I have read about this as a fix, but have not tried it. There is a chance that the dish box or the replay box could be damaged.
I'm only offering this info for the very brave. The IR upgrade is cheap and easy if you know how to solder. a little harder if you don't.
- hastypete
support your local laserist, go see a laser show.
- hastypete
hastypete is offline
post #7 of 11 Old 12-04-2000, 01:48 PM - Thread Starter
kbright's Avatar
Thanks Doc.
Mike thanks for the additional advice.
Question for all:
Do I have to leave the Dish receiver on all the time. I did a test delayed recording and turned everything off and only got blank screens nicely packaged in my replay guide to watch anytime I want.
I assume there is nothing we can do about this, since a "Power On" is probably the same as "Power Off" for the receiver.
Keith
PS: Anybody have any luck with the new Philips universal remote in this type of environment?
kbright is offline
post #8 of 11 Old 12-04-2000, 03:23 PM - Thread Starter
kbright's Avatar
I was thinking of the Philips TSU2000 Pronto. I have a lot of X-10 stuff also and heard it can control that stuff as well. I friend of mine showed me on his laptop the software that lets you program the Pronto and it looks very flexible.
Keith
kbright is offline
post #9 of 11 Old 12-04-2000, 09:06 PM - Thread Starter
kbright's Avatar
Thanks everyone,
I think this forum is great, and I did eventually find the link to the site that describes a hardware modification to my JVC receiver. It worked great and was very easy. The URL is http://www.carltonbale.com/dish/
Just having people give direct answers or links to answers already given is helpful. Not everybody has time to spend learning how to search when they can just ask.
Thanks again
Keith
kbright is offline
post #10 of 11 Old 12-05-2000, 02:59 AM
ADent's Avatar
Originally posted by ReplayMike:
Your much simpler choice might be to invest the $99 for one of Dish's low-end "second room" Dish receivers, solely for use with the ReplayTV.
I think Target has the Phillips version of the 2700/2800 on sale for $50 again.
ADent is offline
post #11 of 11 Old 12-05-2000, 01:17 PM
The Robman's Avatar
Quoted: 45 Post(s)
Keith
The Pronto is very flexible, for ALOT more info on it, visit http://www.remotecentral.com Also, you can get it for only $265 from http://www.etronixs.com (it's MSRP is $400!).
Regarding X10, you will need to get an IR to X10 converter (IR543 or 4040) to be able to control X10 with an infrared remote. You can also control X10 with most One For All and Radio Shack remotes.
Later,
Rob.
http://www.hifi-remote.com/
Later, Rob
Select a link for questions on: Remotes, JP1, JP1 Forums
I prefer emails to PMs, my email is rob1 (at) rockabilly (dot) net
The Robman is offline
Closed Thread ReplayTV & Showstopper PVRs
