UPC # for Replay 3060? - AVS Forum | Home Theater Discussions And Reviews
Old 12-04-2000, 02:19 PM - Thread Starter
genearch's Avatar
Howdy,
Just received my 3060. The UPC code is a bit munged, but I'm sure that ReplayTv will accept it just fine. Mercata put the shipping sticker on top of the code #'s and I can't make them out. Can anyone help out so I can complete the rebate form?
TIA
Gene
genearch is offline
Old 12-04-2000, 04:18 PM
Buffalo Sue's Avatar
They did that on mine, too. I was able to peel off the serial # sticker from the box, and by holding it up to light I could read the UPC code thru the Mercata sticker that was on top of it.
You can get the serial # from the menu/setup/register screen. If someone can verify that all 3060's have the same UPC, I can dig up my xerox of my rebate form and get the UPC for you.
Buffalo Sue is offline
Old 12-04-2000, 04:36 PM - Thread Starter
genearch's Avatar
I have no problem sending it in, I'm sure it's acceptable. It's just that I cannot make out the UPC numbers clearly to put them on the rebate form. I can see the serial # just fine.
Peeling it off, even carefully isn't going to make it any more readable.
Gene
genearch is offline
Old 12-05-2000, 12:42 AM
DJEvans240's Avatar
I had the same problem last month with my RTV3060 from Mercata. I called their customer service and they sent me a letter on their letterhead concerning the sticker over the UPC code. Replay said that this was OK to send in with the rebate stuff.
Dave Evans
Austin, Texas
Dave Evans
Austin, Texas
DJEvans240 is offline
