Announcing: WiRNS 1.0.0 SP PreAlpha - Page 7 - AVS Forum | Home Theater Discussions And Reviews
Old 03-05-2004, 11:54 AM - Thread Starter
kjac's Avatar
On that note, new version posted;
changes:
Should fix 4000 dots issue.
Should fix channel ordering issue.
Let me know
-kjac
kjac is offline
Old 03-05-2004, 11:59 AM
supergenius's Avatar
Ok, I'll setup Wirns to intercept my DTV requests too and see how it goes...
Another quick question.....I know its been hinted that we might eventually be able to insert PPV listings into the guide....any more info on this (ie - what providers can we do this for - DTV, BEV hopefully). Just curious.....
- Super.
Edit.
Just saw the new post, I'll give it a go with my 4500 in a couple of hours when I get home from work.
aka Petroeng @ Poopli.
supergenius is offline
Old 03-05-2004, 12:27 PM
jvidalny's Avatar
New to Wirns and have a ?.
I have Dish and Cablevision, and there are a couple of channels on my cable box lineup that don't match the Cablevision lineup. Is there a way to override/change specific channels so that they match?
jvidalny is offline
Old 03-05-2004, 12:53 PM
Londo's Avatar
changes:
Let me know
-kjac
remember to stop Windows time service? (before I try this on a Win98 machine).
You know, I used to think it was awful that life was so unfair. Then I thought, wouldn't it be much worse if life were fair, and all the terrible things that happen to us come because we actually deserve them? So now I take great comfort in the general hostility and unfairness of the universe.
Londo is offline
Old 03-05-2004, 01:00 PM
cliffcor's Avatar
Should fix channel ordering issue.Let me know-kjac
The dots now appear on my guide. Looks good. That error echo I reported this morning still shows up, but I can't see what's triggering it. The guide looks fine.
Cliff
cliffcor is offline
Old 03-05-2004, 01:29 PM
docmcse's Avatar
changes:
Let me know
-kjac
The sort order is getting better however in my line-up Channel 3 is in between channel 27 and channel 30. the sort needs to presume all channel numbers are padded with leading zeros. Since the largest number of digits in all channel line-ups is 4, the following would be how channels 3 25 301 and 4001 would look
0003
0025
0301
4001
This would fix the channel ordering issue.
Simply one man's opinion!
docmcse is offline
Old 03-05-2004, 01:32 PM - Thread Starter
kjac's Avatar
0003
0025
0301
4001
The reason is because I'm using a SortedList, that has multiple values in the key, I'll have to reorder some things around. I hoped that changing it slightly would fix it.. guess not. :)
-kjac
kjac is offline
Old 03-05-2004, 01:52 PM
lonetreejim's Avatar
kjac,
What does it mean when it says "Starting guide update timer." during the initialization?
ltj
LonetreeJim
lonetreejim is offline
Old 03-05-2004, 01:54 PM - Thread Starter
kjac's Avatar
Originally posted by lonetreejim
kjac,
ltj
ltj,
The code automatically triggers a guide update every 24hrs from DD's servers.
docmcse,
What provider are you having problems sorting with? I'm trying to replicate here.
-kjac
kjac is offline
Old 03-05-2004, 02:10 PM
docmcse's Avatar
Kjac,
Check out this article and the associated source code to see if you could use it with the channel sort issue. (Watch out in case it wraps)
http://www.dotnet247.com/247referenc.../cssorters.asp
docmcse is offline
Old 03-05-2004, 02:17 PM
docmcse's Avatar
docmcse,
-kjac
The provider is "Comcast Atlanta Classic" found using the zipcode 30078. When I open a browser to http://127.0.0.1:8923/manage/GuideServer the first channel listed is 10 (WUPA)...Channel 3 (WSB) is down the list in between the highest os the ones in the 20's and before channel 30. So it is seeing the single digit 3 and compareing it to the first digit in the 10's and in the 20's rather than numerically.
docmcse is offline
Old 03-05-2004, 02:37 PM
So does that mean I can start the server at boot time, let it run 24/7 and it will automatically update the guide data every 24 hours from the guide data source _and_ load the guide data into memory waiting for the RTV to call home?
ltj
EDIT: And BTW, what is DD?
LonetreeJim
Old 03-05-2004, 02:48 PM
jvidalny's Avatar
Regarding the GuideServer sort order:
For example, on the Replay the channels would show up as:
2
105
200
On the GuideServer they show up as:
105
2
200
Was this done by design?
jvidalny is offline
Old 03-05-2004, 03:27 PM
docmcse's Avatar
I think it is DataDirect, which as I understand is the place/method WiRNS uses to download guide information.
On the channel sort issue, it seems the sort is string based (by the ANSI code of each character) and is comparing the first character in each string. The alternative is to sort numerically where a lower valued number is always above the numbers which are greater than it's value.
docmcse is offline
Old 03-05-2004, 03:54 PM
Has anyone been able to access GuideServer from a PC other than the one running WiRNS? I read earlier that port 80 will work but my request (http://192.168.2.97:80/GuideServer?) returns a "Can't find server" error message.
ltj
LonetreeJim
Old 03-05-2004, 05:05 PM - Thread Starter
kjac's Avatar
ltj
ltj,
192.168.2.97:80/index/GuideServer
-kjac
docmcse,
I know how to sort it, its just not implementing my icomparable properly for some people (it works here just fine), I'm going to add your lineup later tonight/this weekend and try to replicate.
-kjac
kjac is offline
Old 03-05-2004, 05:14 PM
Lee Thompson's Avatar
DataDirect is a new free* service from Tribune Media Services for projects like this, Personal ReplayGuide and others that use TV listing data.
(OT: PRG support for DD is already finished and well tested but I have other things to fix and add before the next release.)
DataDirect is a product of the new "Zap2It Labs", which is why sometimes you see the URL as http://datadirect.zap2it.com and other times http://labs.zap2it.com .... they go the same place.
* the price is to fill out a short quarterly survey.
Lee Thompson is offline
Old 03-05-2004, 05:15 PM - Thread Starter
kjac's Avatar
1.0.9 is out..
for DISH ppv, edit the file in PPVConfigs accordingly and move it into the folder that wirns.exe is in.
-kjac
kjac is offline
Old 03-05-2004, 05:21 PM
greenall's Avatar
Kjac.
Question for you. Currently I just proxy through to get the directtv listings because I still would like the serial control of the receiver. Is there any way to keep the serial control and use wirns on a provider. Could a possibility be to setup the replay to use directtv as normal, and then setting up wirns to serve the channels after, without changing the postal code?
Rich
greenall is offline
Old 03-05-2004, 05:39 PM
Londo's Avatar
Ah crap.. I know why thats happening.. I'll fix that in a subsequent release (NTP Proxy has to stop Windows Time Service if its running)
-kjac
just tried 0.9, same thing, still crashes out on (three different) win98 machines the same way...
Londo is offline
Old 03-05-2004, 05:42 PM - Thread Starter
kjac's Avatar
Londo,
Sorry, I keep forgetting that fix.. I'll add it into 1.0.10
-kjac
kjac is offline
Old 03-05-2004, 05:44 PM - Thread Starter
kjac's Avatar
Originally posted by greenall
Kjac.
Rich
greenall,
That should work. I'm still working to determine the "black magic voodoo" that DNNA uses to determine if serial control is available (I thought it would be in the ir field, but it aint there iirc, I'll check again).
-kjac
kjac is offline
Old 03-05-2004, 06:27 PM
cliffcor's Avatar
Just checking to see if the below is telling me something I need to react to.
[2004-03-05 11:20:52] Refreshing RecordingGuide for: Junglist(192.168.1.200)
[2004-03-05 11:22:23] WiRNS v1.0.8 - (c) 2004 kjac
[2004-03-05 11:22:23] Thanks: ijprest, waynethedvrguy, Remmer99, gduprey, LeeThompson, j.m. and all the other Replay Hackers out there.
[2004-03-05 11:22:23] Initializing.
[2004-03-05 11:22:23] Cleaning up database.
[2004-03-05 11:22:23] Vacuuming database
[2004-03-05 11:22:31] Detected that I'm running from command line.
[2004-03-05 11:22:31] Loading configuration
[2004-03-05 11:22:31] Starting guide update timer.
[2004-03-05 11:22:31] Detected configuration settings. Starting Replay Emulation server on: 192.168.0.165
[2004-03-05 11:22:31] Loading server plugins.
[2004-03-05 11:22:33] Plugin: ChannelGuideProvider.dll loaded.
[2004-03-05 11:22:33] Updating ReplayGuide information
[2004-03-05 11:22:33] Refreshing RecordingGuide for: Cliff(192.168.1.170)
[2004-03-05 11:22:43] There was an error refreshing the recording guide.
[2004-03-05 11:22:43] Attempting to use a cached version if one is available.
[2004-03-05 11:22:44] Parsed 62/63 entries.
[2004-03-05 11:22:44] Plugin: GuideServer.dll loaded.
[2004-03-05 11:22:44] Plugin: HeadendProvider.dll loaded.
[2004-03-05 11:22:44] Plugin: PutSyslogProvider.dll loaded.
[2004-03-05 11:22:44] Plugin: ServerManagment.dll loaded.
[2004-03-05 11:22:44] Plugin: ZipcodeProvider.dll loaded.
[2004-03-05 11:22:44] Replay Network Server Emulation started.
[2004-03-05 11:22:44] Starting configuration server on 127.0.0.1:8923
[2004-03-05 11:22:44] Loading server plugins.
[2004-03-05 11:22:44] Updating ReplayGuide information
[2004-03-05 11:22:44] Refreshing RecordingGuide for: Cliff(192.168.1.170)
[2004-03-05 11:22:54] There was an error refreshing the recording guide.
[2004-03-05 11:22:54] Attempting to use a cached version if one is available.
[2004-03-05 11:22:54] Parsed 62/63 entries.
[2004-03-05 11:22:54] Plugin: GuideServer.dll loaded.
[2004-03-05 11:22:54] Plugin: ServerManagment.dll loaded.
[2004-03-05 11:22:54] Replay Network Server Emulation started.
[2004-03-05 11:22:54] Starting ntp proxy server.
[2004-03-05 11:22:55] Starting DNS Proxy
[2004-03-05 15:22:54] Updating ReplayGuide information
[2004-03-05 15:22:54] Refreshing RecordingGuide for: Cliff(192.168.1.170)
[2004-03-05 15:23:05] There was an error refreshing the recording guide.
[2004-03-05 15:23:05] Attempting to use a cached version if one is available.
[2004-03-05 15:23:05] Parsed 62/63 entries.
[2004-03-05 15:59:35] Hijacking headend request, because we serve it locally.
[2004-03-05 15:59:36] Hijacking headend request, because we serve it locally.
[2004-03-05 16:01:00] DEBUG: URI:http://production.replaytv.net/cgi-b...516H2AA7000030
[2004-03-05 16:01:00] DEBUG: HeaderException (dump to follow):
[2004-03-05 16:01:00] DEBUG: Content-Type:application/vnd.replay.transaction
[2004-03-05 16:01:00] DEBUG: X-Replay-Serial-Number:RTV4516H2AA7000030
[2004-03-05 16:01:00] DEBUG: Authorization:Basic Uk5TQmFzaWM6QTd4KjgtUXQ=
[2004-03-05 16:01:00] DEBUG: Accept-Encoding:gzip
* Couple more lines in the command box not in the log file
[info] exception caught in handler: wirnsproxyheaderexception at wirns.server.replaynetworkserver.proxyrquest(string message, boolean return headers) at wirns.server.replaynetworkserver.handlemessage(stringmessage , socket handler) at wirns.server.replaynetworkserver.readcallback(iasyncresult l_asynchres)
cliffcor is offline
Old 03-05-2004, 06:40 PM - Thread Starter
kjac's Avatar
cliff,
Nothing to react to, it does help me track down that bug tho. Should be fixed in the next version.
-kjac
kjac is offline
Old 03-05-2004, 07:04 PM - Thread Starter
kjac's Avatar
On the PPV note btw; I've started looking into the BEV ppv parser, its gonna be a bitch, but its definately doable, so I have two questions:
1) Does anyone else want to write some vb.net or c#.net code for the bev parser? (Preferably VB.Net)
2) Does anyone know another place that bev PPV listings are online other than their website?
-kjac
kjac is offline
Old 03-05-2004, 07:27 PM
ltj,
-kjac
No joy. The following exception was generated (honest, I did type the :80).
[2004-03-05 21:05:26] DEBUG: URI:http://192.168.2.97/index/GuideServer
[2004-03-05 21:05:26] DEBUG: HeaderException (dump to follow):
[2004-03-05 21:05:26] DEBUG: Accept-Language:en-ca
[2004-03-05 21:05:26] DEBUG: Accept-Encoding:gzip, deflate
[2004-03-05 21:05:26] DEBUG: Connection:Keep-Alive
[INFO] Exception caught in handler: WiRNSProxyHeaderException
at WiRNS.Server.ReplayNetworkServer.ProxyRequest(String message, Boolean retu
rnHeaders)
at WiRNS.Server.ReplayNetworkServer.HandleMessage(String message, Socket hand
ler)
at WiRNS.Server.ReplayNetworkServer.ReadCallBack(IAsyncResult l_AsyncRes)
I'm running IIS on this PC for FTP (not HTTP). Think that might cause a problem?
LonetreeJim
Old 03-05-2004, 07:29 PM - Thread Starter
kjac's Avatar
rnHeaders)
ler)
lonetree,
That error isn't fatal, its emitting debugging information for me to resolve it (see above to my post to cliffcor), as for why that error appeared? Simple explanation, I made a typo:
should be /manage/GuideServer.
-kjac
kjac is offline
Old 03-05-2004, 07:34 PM
Your so smart!
LonetreeJim
Old 03-05-2004, 08:11 PM
jvidalny's Avatar
Problems I'm having:
I made changes in the Zap2it Labs channel lineup (selecting/unselecting channels), then I forced a net connect to get the latest channel guide info, but then it hung for a long time in the combining stage.
Then when it finally came back, it said it needed to do a maintenance reboot, but after the reboot, the Replay hung and wouldn't respond.
I ended up having to remove the network cable, and doing a power reset, which cleared up the hang problem, but when I went to the channel guide, the channels I originally added via zap2it labs are still missing.
Hope that's clear.
jvidalny is offline
Old 03-05-2004, 08:30 PM
natemg's Avatar
Sorting seems to be working correctly now.
natemg is offline
