WiRNS 1.1.x Beta - Page 4 - AVS Forum | Home Theater Discussions And Reviews
Old 03-30-2004, 03:17 PM
Bigjohns's Avatar
ok, the IP of the RTV not the WIRNS PC.
I'll try that tonight after our recordings are finished.
Bigjohns is offline
Old 03-30-2004, 05:32 PM - Thread Starter
kjac's Avatar
Originally posted by Bigjohns
Seems that in WIRNS world, 5:30 comes right after 0:00...
tracked down and fixed..
-kjac
kjac is offline
Old 03-31-2004, 02:51 PM
Bigjohns's Avatar
Originally posted by kjac
John,
Do another connect/ethereal dump so I can take a look whats going on..
-kjac
here is etherreal dump for 192.168.0.51 (familyroom RTV).
Dyn DNS did catch and spoof packets, but DVArchive was getting the PING request!
MY PC:
192.168.0.55 = primary IP / DVarchive
192.168.0.100 =secondary IP / wirnsIP
ONE default gateway is programmed - 192.168.0.1 (SMC Baricade G router)
My ISP DNS addresses are hard coded.
John
Bigjohns is offline
Old 03-31-2004, 02:53 PM
Bigjohns's Avatar
Bigjohns is offline
Old 03-31-2004, 03:46 PM - Thread Starter
kjac's Avatar
File attached...Arrgh.
Bigjohn,
It appears that micro_dns is responding with your primary ip instead of your wirns ip. I dont know how ti can do this (it doesn't for anyone else). Do you have some other DNS software running on your pc or anything like that? Can you try swapping wirnsip and dva ip so that wirns is the primary and see what happens?
-kjac
kjac is offline
Old 03-31-2004, 03:51 PM
Bigjohns's Avatar
Bigjohns is offline
Old 03-31-2004, 04:19 PM
Bigjohns's Avatar
Wirns now worked.
Here is the etherreal
John
bigjohn-4.txt 11.3984375k . file
Bigjohns is offline
Old 03-31-2004, 04:21 PM - Thread Starter
kjac's Avatar
Wirns now worked.
John
Good.. leave it like that then :)
-kjac
kjac is offline
Old 03-31-2004, 06:31 PM
Bigjohns's Avatar
Umm, yeah... but whats up with MicroDNS doing that crap??
John
Bigjohns is offline
Old 03-31-2004, 06:48 PM - Thread Starter
kjac's Avatar
John
Dunno, I'm rebuilding it into managed code soon anyways.
-kjac
kjac is offline
Old 04-01-2004, 09:59 AM
Bigjohns's Avatar
rebuild todolist = endless loop?
I'm not sure if this is a known bug or not. But I went through the server console to tell wirns to rebuild the todo list - and
Code:
004-04-01 11:54:42] Parsed 36/36 entries.
004-04-01 11:54:42] Building ToDo List for: BedRoom
004-04-01 11:54:42] Refreshing RecordingGuide for: FamilyRoom(192.168.0.51)
004-04-01 11:54:51] Parsed 57/57 entries.
004-04-01 11:54:51] Refreshing RecordingGuide for: BedRoom(192.168.0.41)
004-04-01 11:54:57] Parsed 36/36 entries.
004-04-01 11:54:57] Building ToDo List for: BedRoom
004-04-01 11:54:57] Refreshing RecordingGuide for: FamilyRoom(192.168.0.51)
004-04-01 11:55:06] Parsed 57/57 entries.
004-04-01 11:55:06] Refreshing RecordingGuide for: BedRoom(192.168.0.41)
004-04-01 11:55:12] Parsed 36/36 entries.
004-04-01 11:55:12] Building ToDo List for: BedRoom
004-04-01 11:55:12] Refreshing RecordingGuide for: FamilyRoom(192.168.0.51)
004-04-01 11:55:21] Parsed 57/57 entries.
004-04-01 11:55:21] Refreshing RecordingGuide for: BedRoom(192.168.0.41)
004-04-01 11:55:27] Parsed 36/36 entries.
004-04-01 11:55:27] Building ToDo List for: BedRoom
004-04-01 11:55:27] Refreshing RecordingGuide for: FamilyRoom(192.168.0.51)
004-04-01 11:55:36] Parsed 57/57 entries.
004-04-01 11:55:36] Refreshing RecordingGuide for: BedRoom(192.168.0.41)
004-04-01 11:55:42] Parsed 36/36 entries.
004-04-01 11:55:42] Building ToDo List for: BedRoom
004-04-01 11:55:42] Refreshing RecordingGuide for: FamilyRoom(192.168.0.51)
004-04-01 11:55:50] Parsed 57/57 entries.
004-04-01 11:55:50] Refreshing RecordingGuide for: BedRoom(192.168.0.41)
004-04-01 11:55:57] Parsed 36/36 entries.
004-04-01 11:55:57] Building ToDo List for: BedRoom
004-04-01 11:58:11] Building ToDo List for: FamilyRoom
004-04-01 11:58:13] Building ToDo List for: FamilyRoom
004-04-01 11:58:14] Building ToDo List for: FamilyRoom
004-04-01 11:58:15] Building ToDo List for: FamilyRoom
004-04-01 11:58:16] Building ToDo List for: FamilyRoom
004-04-01 11:58:18] Building ToDo List for: FamilyRoom
004-04-01 11:58:19] Building ToDo List for: FamilyRoom
Whoa!
Bigjohns is offline
Old 04-01-2004, 10:08 AM - Thread Starter
kjac's Avatar
John,
This is a known bug. It only happens sporadically. The timer seems to fire multiple times occasionally, and I'm not sure why yet.. I'm tracing in debuggers and not seeing it happen, so its a little weird. :)
-kjac
Code:
Whoa!
kjac is offline
Old 04-01-2004, 02:25 PM
Bigjohns's Avatar
Ahhh... I see.
Hey, is there anyway you can put a checkbox in here that says: Force NBC shows to start at :00?
Damn NBC seems to be doing the x:59 jig again next week...
Also, in the guide - I'm curious.. what value does the 'switch dvr' option select have? You combine all the data from the guide and both DVRs on that screen anyway!
John
Bigjohns is offline
Old 04-01-2004, 02:27 PM - Thread Starter
kjac's Avatar
Ahhh... I see.
John
It builds the lineup for the dvr you're looking at. If you have totally different lineups on your dvrs (which some people do) its more functional. For people like you, with the same lineup? Not much :)
-kjac
kjac is offline
Old 04-01-2004, 02:37 PM
Bigjohns's Avatar
-kjac
Ahh, I see....
But.. um, what about my other question? I'd like to be able to force all shows to start on the hour if they're a minute off....
Bigjohns is offline
Old 04-01-2004, 02:42 PM - Thread Starter
kjac's Avatar
Ahh, I see....
I asked about this a long time ago and people expressed very little interest. Now that its back I'll look into it again.
-kjac
kjac is offline
Old 04-01-2004, 03:04 PM
Bigjohns's Avatar
COOL! That would be massive. Especially since I'm using WIRNS as the guide for both my RTVs....
Bigjohns is offline
Old 04-02-2004, 09:04 AM
duckman360's Avatar
I too would like that feature Kjac...
Keep up the AWESOME work man. This program keeps getting better and better.
You changed the plugin format, do you have it documented some where how it needs to be inorder to create a plugin?
CP
duckman360 is offline
Old 04-02-2004, 10:03 AM - Thread Starter
kjac's Avatar
CP
duck,
If you extract from CVS, you'll see all the plugin projects that implement the needed interface. There are four public methods they need to expose
SetRNSIP()
SetRNSPort()
SetRNSDelimeter()
HandleMessage()
(iirc). They're something like that. Check out the PutSyslogPlugin, its the simplest.
-kjac
kjac is offline
Old 04-04-2004, 10:12 PM
Bigjohns's Avatar
kjac -
what happened to the part of the to-do list where it would have some shows listed with 'nothing scheduled'? I found this to be helpful because it allowed me to find shows that had MOVED days or timeslots (or both).
In fact, i'd been meaning to ask for you to allow us to do a 'search for all episodes' by clicking those. Maybe have 2 options - search for all, or search for all on scheduled station.
John
Bigjohns is offline
Old 04-04-2004, 10:22 PM - Thread Starter
kjac's Avatar
kjac -
John
john,
That feature was temporarily removed with the todolist rebuild, its coming back.
I'll look into the search possibilities.
-kjac
kjac is offline
Old 04-04-2004, 10:34 PM
Bigjohns's Avatar
Cool!
Hope you're still considering the todo as I described it!
John
Bigjohns is offline
Old 04-05-2004, 12:25 AM - Thread Starter
kjac's Avatar
Cool!
John
You mean the blocks in the channel guide? I did the red blocks n the time code for that, thought that would roughly achieve the same goal no?
-kjac
kjac is offline
Old 04-05-2004, 06:47 AM
seanwg's Avatar
Is there any way todo channel re-mapping?
I live in Bermuda; Zap2It has setup a phony postal code for the local cable co, but unfortunately it won't provide any data on the DataDirect application.
I found a couple of cable cos in the US which provide practically the same lineup, but they channels are in different places.. is there anyway to re-map what the replaytv receives?
Ie HBO on channel 41 on Zap2ItData, is actually 71 on my local cable co
Sean
seanwg is offline
Old 04-05-2004, 09:12 AM - Thread Starter
kjac's Avatar
Sean
With 1.x no, with 0.x yes. Its coming for 1.x, no ETA tho.
-kjac
kjac is offline
Old 04-05-2004, 08:37 PM
Bigjohns's Avatar
kjac -
noticed tonight (and other nights this week) dots missing on shows that OUGHT to be recorded.
I told wirns to poll the RTV's (update rtv) and they did... still, no dots...
John
Bigjohns is offline
Old 04-05-2004, 09:53 PM - Thread Starter
kjac's Avatar
kjac -
John
Yeah, some people are having problems with this, I have some debug info, I think its people with multimap lineups.
-kjac
kjac is offline
Old 04-05-2004, 10:40 PM
Brin's Avatar
Having some network problems lately, but don't have time to do much troubleshooting -- not asking for help there. All was working about 2 weeks ago. I use WiRNS to get my Rogers Cable listing.
My concern is with my activation.
Will my RTV deactivate if it does not connect in time to mothership?
I understand that WiRNS passes that information through, but at the moment I am a bit messed up with my network.
My unit says it is activated until 5/2 (I am on monthly plan -- this is my second month)
But unit also says it last connected 3/16/2004
And my Guide is current until tomorrow Wed 4/7 so I did connect via WiRNS after the date my Replay last knows about, 3/16+12 days of Guide would be 3/28 and I am more than a week past that.
What happens if I dont get my guide update working by Wednesday?
Will my Replay stop working when the guide expires? Will the manual recording still work until my activation date? (assuming the unlikely event that I dont get it working by then) Can an expired RTV be reactivated? Is there a penalty? How many more questions will I ask?
Seriously, any help would be appreciated.
-- Brin
Brin is offline
Old 04-05-2004, 11:59 PM - Thread Starter
kjac's Avatar
-- Brin
Brin,
Some of my answers are supposition, and some are fact. All of the supposition are educated guesses tho:
If you hit activation before connecting your replay will turn into a doorstop.
If this does happen, as soon as you have your next succesfull connect up, it will start working again.
All recordings should work (manual or otherwise) until your activation date.
-kjac
kjac is offline
Old 04-06-2004, 01:14 AM
Blaze's Avatar
Is there a way to make a Local Broadcast on DD appear in the Satellite providers. I am trying to run my HD tuner through my Replay. No cable, no Satellite, just antenna. The regular NTSC picture is bad, but digital is perfect through s-video.
All of the digital stations are in the DD listing. I am planning on getting the listings setup first before tackling the IR.
I am not sure if this has been discussed in other threads. I looked, but no solution.
Blaze
Blaze is offline
