IR Blaster Port - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 08-14-2004, 01:45 PM - Thread Starter
dschoemaker's Avatar
Didn't see any answer in faq to this.
I recently got a second Showstopper (80 hours - Unit #2). I plugged it into the same system (inputs, power, outputs, IR cable blaster) as my current Showstopper (120 hours - Unit #1) and the IR blaster does not work on my General Instruments Cable Box. Went through set up as normal and set the Cable Box code the same as Unit #1.... no joy. Unplugged it all and put unit 1 back on line - worked fine.
Took unit #2 and plugged it into straight cable, using the box as the tuner and it works fine on the set upstairs. I can live with this set up... but is there a way to work around the IR Blaster problem if I end up getting another cable box for the upstairs set?
Thanks for any help.
Movie Buff Extraodinaire
dschoemaker is offline
post #2 of 2 Old 08-14-2004, 03:17 PM
Mikeyboy's Avatar
Not that I'm aware of. It certainly sounds like you've troubleshoot the problem correctly. Replacing the motherboard is the usual fix. www.ReplayTvParts.com
Mikeyboy is offline
Closed Thread ReplayTV & Showstopper PVRs
