WiRNS 1.2.x - Page 19 - AVS Forum | Home Theater Discussions And Reviews
Closed Thread
post #541 of 559 Old 02-03-2005, 11:56 AM - Thread Starter
rbolen70's Avatar
Originally posted by Bigjohns
When I restart in APP mode I have a channel guide immediately.
if you start back up in service mode, what happens?
rbolen70 is offline
post #542 of 559 Old 02-03-2005, 02:11 PM
Sean_S's Avatar
Ryan,
Working great.
Did notice that the foreign text characters--accents, etc.--look good on the WiRNS channel guide, but are still not working correctly on the Replay.
Sean
Sean_S is offline
post #543 of 559 Old 02-03-2005, 10:11 PM
Bigjohns's Avatar
canceld APP mode.
Started Service Mode
GUIDE OK
Manual guide update intiated
Guide OK.
Could have been a one time glitch? or something caused by leaving the browser on the old data overnight?
Bigjohns is offline
post #544 of 559 Old 02-06-2005, 09:08 AM
jgmace's Avatar
I can get the unit 5504 with image 5040_530510190.rtv to connect through Wirns 1.1.2b and update all the information. It completes up to the "Combining Data" stage and hangs at 75%.
This appears to be the error message
INFO] Exception caught in handler: Object reference not set to an instance of a
n object.
at WiRNS.Server.ReplayNetworkServer.ProxyRequest(String message, Byte[] conte
nt, Boolean returnHeaders)
at WiRNS.Server.ReplayNetworkServer.HandleMessage(String message, Byte[] requ
estContent, Socket handler)
at WiRNS.Server.ReplayNetworkServer.ReadCallBack(IAsyncResult l_AsyncRes)
Do you have any advise?
My RTV's
5040 w 200GB
5504 w 120 GB
jgmace is offline
post #545 of 559 Old 02-06-2005, 10:31 AM
RTK
RTK's Avatar
Quoted: 115 Post(s)
its been a while but I had a similar issue once when I had the wrong gateway entered in the RTV setup menu
Rick
RTK is offline
post #546 of 559 Old 02-07-2005, 06:10 AM
jgmace's Avatar
Thanks for the reply. What I found was I had entered the wrong gateway in the Wirns setup page. Corrected that and everything worked. Now that I have it set up, will the Replay try to access the mother ship automatically as in the past? If so I guess I need to keep Wirns running all the time.
If the RTV were to try to connect without Wirns running would it be able to connect and would that allow it to download the new software?
Is there a way to keep Wirns running and to be able to use DvArchive and the Poopli updater at the same time?
My RTV's
5040 w 200GB
5504 w 120 GB
jgmace is offline
post #547 of 559 Old 02-07-2005, 06:23 AM
l8er's Avatar
WiRNS and DVArchive just need separate IPs to run at the same time. The Poopli Updater really has nothing to do with either one of them.
-Gary
ReplayTV DIY Information/Repair/Upgrade Site: www.replaytvupgrade.com
l8er is offline
post #548 of 559 Old 02-07-2005, 06:26 AM
jgmace's Avatar
Pardon my ignorance. How do I give them separate IPs on the same machine?
My RTV's
5040 w 200GB
5504 w 120 GB
jgmace is offline
post #549 of 559 Old 02-07-2005, 07:07 AM
Bigjohns's Avatar
In win2k you go into the network config, set your main address STATIC. Then go to the advanced tab and add another IP address to your nic.
Bigjohns is offline
post #550 of 559 Old 02-07-2005, 07:12 AM
l8er's Avatar
In Windows XP and Win2k, you can give a network adapter multiple IP addresses. (in XP, it's Network Connections, then Properties for the NIC, under TCP/IP properties, Advanced, IP Addresses, Add.)
So if, for example, your NIC is already assigned 192.168.1.1, you could add 192.168.1.10. Then in DVArchive's set up, tell it to use 192.168.1.10 and allow WiRNS to use the default 192.168.1.1.
Assigning multiple IPs to a NIC is also possible in Windows 98, but it takes editing the registry to do it. (Here's a link to some info.)
-Gary
l8er is offline
post #551 of 559 Old 02-07-2005, 07:12 AM
jgmace's Avatar
Thanks. Will this also work in XP pro?
My RTV's
5040 w 200GB
5504 w 120 GB
jgmace is offline
post #552 of 559 Old 02-07-2005, 07:15 AM
jgmace's Avatar
Thanks, I apparently was asking the previous questions while you were typing the answer above.
My RTV's
5040 w 200GB
5504 w 120 GB
jgmace is offline
post #553 of 559 Old 02-10-2005, 10:49 AM
sudhs's Avatar
The 1.3.1.1 is not working for me. It recognizes my replays but whenever I try to add a new PPV (Dish Detroit) is shows me a blank error page and then everything falls apart. The guide update also terminates giving an exception. All was working good till yesterday with 1.3.1 on Feb 3rd release. All of a sudden, everything's dead. Database locked exceptions all over. nebo
JVC HD-P61R1U, BOSE LifeStyle 50, BOSE C-1024 Mod, Audio Auth 1154A Switch, ReplayTV 5504/5040/WIRNS/DVA, Slingbox, PANSAT 2500A, 2700A, DVP642/37 Philips DVD, Panny CP-72 DVD
sudhs is offline
post #554 of 559 Old 02-10-2005, 10:49 AM
sudhs's Avatar
sudhs is offline
post #555 of 559 Old 02-10-2005, 10:50 AM
sudhs's Avatar
Oops.. Double post regretted..
sudhs is offline
post #556 of 559 Old 02-10-2005, 04:25 PM
Sean_S's Avatar
sudhs, I had the same problem. I was running from command line. I just restarted after getting the error adding ppv. I was then able to add and do a guide update. I should note that I deleted the database and its backup file before launching 1.3.1.1.
BTW, you should probably start posting in Ryan's 1.3.1 thread. ;)
Sean
Sean_S is offline
post #557 of 559 Old 02-10-2005, 04:57 PM
l8er's Avatar
And only posting once.
-Gary
l8er is offline
post #558 of 559 Old 02-10-2005, 06:31 PM
burger23's Avatar
I tried this-- added 192.168.1.10 as a second IP address. Then went into DVA and selected the above address, saved it, and restarted DVA. DVA reports it can not start the server because another program is using port 80.
I am using static IP's. What else should I do?
The Burger
burger23 is offline
post #559 of 559 Old 02-11-2005, 03:46 AM
l8er's Avatar
If you just added that IP then nothing else should be using it, but then again, this is Windows we're talking about. Try leaving DVArchive on the default initial IP for the NIC and tell WiRNS to use the second IP. And/or add another IP and tell WiRNS to use it.
On my PC, 192.168.1.1 is the default initial IP for the NIC. I added 192.168.1.10 and changed DVArchive to use it, and added 192.168.1.20 and changed WiRNS to use it. (WinXP Pro SP2).
My example of adding 192.168.1.10 is based on the initial default IP being 192.168.1.1. If your LAN is using something other than 192.168.1.X then you need to adjust accordingly.
-Gary
l8er is offline
Closed Thread ReplayTV & Showstopper PVRs
