WiRNS 1.2.x - Page 4 - AVS Forum | Home Theater Discussions And Reviews
Old 12-09-2004, 07:55 AM
supergenius's Avatar
Originally posted by Bigjohns
I'm not getting any guide updates....
I'm using a slightly older version of wirns service, though - from november 12th.
It seems to "STOP" getting updates after a few days running. Today, no data at all. Can't even load a guide.
John
Yeah, I think we are all having problems. Must be something going on with Datadirect.
aka Petroeng @ Poopli.
supergenius is offline
Old 12-09-2004, 09:10 AM - Thread Starter
rbolen70's Avatar
Zap2it changed their xml schema.. I'm looking into it...
rbolen70 is offline
Old 12-09-2004, 09:39 AM
Bigjohns's Avatar
Bigjohns is offline
Old 12-09-2004, 09:43 AM
Sean_S's Avatar
Bummer... Just another monkey wrench thrown at the project, huh? If it's not one thing it's another. Just when you think you're there.
(I'm out of cliches) ;)
Sean
Sean_S is offline
Old 12-09-2004, 11:51 AM
waynethedvrguy's Avatar
This may have something to do with it:
http://bb.labs.zap2it.com/posting.php?mode=quote&p=1329
Wayne
Go Ahead.....
Take a look at MY POOP
MY POOP don't stank!!!
waynethedvrguy is offline
Old 12-09-2004, 12:01 PM
cliffcor's Avatar
Regards,Wayne
Yeah, guess so.
Cliff
cliffcor is offline
Old 12-09-2004, 12:35 PM - Thread Starter
rbolen70's Avatar
Yeah..
KJac is working on a patch for the DD listings.
Thread can be followed here:
http://www.planetreplay.com/phpBB2/viewtopic.php?t=9270
rbolen70 is offline
Old 12-09-2004, 02:54 PM
kjac's Avatar
Hi all,
I can't attach patches there;
here ya go rbolen replace with this and you should be good
-kjac
PS. Remeber to fix the namespace.
datadirectlistings.txt 21.74609375k . file
kjac is offline
Old 12-09-2004, 03:25 PM - Thread Starter
rbolen70's Avatar
Kjac.. I get this:
[2004-12-09 16:24:19] Found a new lineup to add: DIRECTV Colorado Springs
[2004-12-09 16:24:20] Updating lineupmap for: DIRECTV Colorado Springs
Unhandled Exception: Finisar.SQLite.SQLiteException: near "2": syntax error
at Finisar.SQLite.sqlite3.Throw()
at Finisar.SQLite.sqlite3.compile(String zSql)
at Finisar.SQLite.OneSQLStatement.Compile()
at Finisar.SQLite.SQLiteCommand.ExecuteNonQuery()
at WiRNS.WiRNSService.DoGuideUpdate()
^C
rbolen70 is offline
Old 12-09-2004, 04:20 PM
kjac's Avatar
Kjac.. I get this:
^C
rbo,
Dump the sqlite command causing this please
-kjac
kjac is offline
Old 12-09-2004, 04:35 PM - Thread Starter
rbolen70's Avatar
still same thing.. if I completely dump it, we'll lose the headend remapping. I'll have to check it later.. my son has a concert at school tonight...
rbolen70 is offline
rbolen70's Avatar
rbolen70 is offline
rbolen70's Avatar
rbolen70 is offline
Old 12-09-2004, 05:39 PM
kjac's Avatar
Dump meaning show me; not remove from build :)
-kjac
kjac is offline
Old 12-09-2004, 06:49 PM
kjac, Ryan:
Much appreciated.... your efforts on our behalf.
Wayne
Go Ahead.....
Old 12-09-2004, 08:02 PM
kjac's Avatar
rbo,
I implemented it on my wirns tree (albeit very different) and it works fine here; db updated and replay updated without a hitch; its gotta be something local to you / your mods
-kjac
kjac is offline
Old 12-09-2004, 08:24 PM
TheDreamer's Avatar
Any chance you can provide context diffs so that I can see what changed....
The Dreamer.
You may be a dreamer, but I'm The Dreamer, the definite article you might say!
TheDreamer is offline
Old 12-09-2004, 10:59 PM
Carnivore's Avatar
I'm getting the same error Sean_S posted yesterday:
Unhandled Exception: System.NullReferenceException: Object reference not set toan instance of an object.at WiRNS.WiRNSService.
DoGuideUpdate()
My guide isn't updating and I'm not really sure what (if anything) to do with the datadirectlistings.txt file posted by kjac or how to "fix the namespace". Suggestions?
BTW, I tried several fixes including a complete reinstall before coming here to find that something is up with DD so I don't know how that may have affected things on my system.
Carnivore is offline
Old 12-09-2004, 11:45 PM
Guerito's Avatar
Has something changed recently? I've been using v1.1.2 build 1285 for months now without a problem. Now I'm getting,
[DNS] micro_dns listing on port 53
[2004-12-10 02:38:34] Guide update manually initiated.
[2004-12-10 02:38:34] Purging old guide information
[2004-12-10 02:38:36] Updating guide information in the database.
[2004-12-10 02:38:36] Processing guide information for: Fri Dec 10
Unhandled Exception: System.NullReferenceException: Object reference not set to an instance of an object. at WiRNS.WiRNSService.DoGuideUpdate()
It poops out after downloading the first days guide data. I've made no changes whatsoever.
Guerito is offline
Old 12-10-2004, 05:13 AM
l8er's Avatar
Guerito and Carnivore - the format at the zap2it/datadirect end changed 12/8/04 and there's nothing any of us WiRNS end users can do until the changes are coded into the program. kjac is the guy behind WiRNS while rbolen70 has enhanced it. So just sit back and wait until an update gets posted here.
-Gary
ReplayTV DIY Information/Repair/Upgrade Site: www.replaytvupgrade.com
l8er is offline
Old 12-10-2004, 05:15 AM
Stevegs1's Avatar
Mine just hangs on "Processing guide information for Fri Dec 10th"
Stevegs1 is offline
Old 12-10-2004, 05:16 AM
cliffcor's Avatar
The Zap2It data direct feed has made a change in the provided data format. The Wirns folks are working on changing the Wirns system to properly handle the changed format.
At this point, continue to monitor the board here and Planet Replay. I'd be surprised if an updated Wirns is not available shortly.
Cliff
cliffcor is offline
Old 12-10-2004, 05:20 AM - Thread Starter
rbolen70's Avatar
DD's fixed... Thanks KJac!!!
If you're using KJac's last build 1.1.2b:
http://www.users.qwest.net/~bolenbau..._Fix.1.1.2.zip
If you're using 1.2.3:
http://www.users.qwest.net/~bolenbau..._Fix.1.2.3.zip
rbolen70 is offline
Old 12-10-2004, 05:29 AM
Its amazing how we become so dependent on the brilliance of others, and don't really appreciate it until there is a little hiccup in the system ;)
Unfortunately, I/we can only sit back and watch with awe as these people provide the tools we use/need on a regular basis. Without DVarchive/poopli/Wirns my replaytv experience would be much less enjoyable. And for me WiRNS is especially important since its the ONLY way for me to get my Canadian listings imported.
Anyway, I know its been said before, but to all those guys out there who provide us with the applications and guidance (you know who you are!!), we salute you!!!
Old 12-10-2004, 08:05 AM
l8er's Avatar
Looks good! Browsing the database file it looks like it got everything, although I'll double check at home later today, Star ratings, MPAA ratings and the year are back on movie listings.
And for those of you trying to get PPV listings to work...look in the (WiRNS) log file for the name of your line up. Then enter this in the PPV driver set up in WiRNS. I'm not sure if the time zone is critical or not (I entered Central). Using this name, I was able to get PPV listings for the first time this morning for DishNetwork.
Many thanks to kjac, rbolen70 and anyone else involved in the continuing development and support of WiRNS.
-Gary
l8er is offline
Old 12-10-2004, 09:38 AM - Thread Starter
rbolen70's Avatar
rbolen70 is offline
Old 12-10-2004, 09:53 AM
lonetreejim's Avatar
Let me underscore what supergenius, l8er and others have already said.
When I lived in Denver I was able to enjoy all the features of my ReplayTV but when I moved back to Canada I was certain I'd be destined to spend the rest of my life using a Buffalo zip code doing manual records.
kjac and rbolen have added back what makes the Replay experience so worthwhile and I owe you both a debt of gratitude. If you ever need any resources for this project just say the word!
ltj
LonetreeJim
lonetreejim is offline
Old 12-10-2004, 10:07 AM - Thread Starter
rbolen70's Avatar
ltj
As always.. a few more replays would help.. :)
j/k.. Thank you very much!
rbolen70 is offline
Old 12-10-2004, 11:04 AM
Sean_S's Avatar
Thanks, Ryan! I really appreciate your time.
Thanks too, L8ER, for the PPV info. I'm glad you got it working. Can't wait to try it.
Sean
Sean_S is offline
Old 12-10-2004, 12:06 PM
Guys ..... don't forget to follow the planetreplay.com site. There is a post with respect to donations to kjac/Ryan and other developers.
Wayne
Go Ahead.....
