Before you ask... Read the FAQ!!!! - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 2 Post By ClearToLand
post #1 of 7 Old 12-16-2004, 10:00 AM - Thread Starter
The Robman's Avatar
Quoted: 45 Post(s)
New to Replay or just looking for more info? Please be sure to check out our member created REPLAY TV FAQ!!!
http://www.replaytvfaqs.com/
As that URL no longer seems to work, here's an archived version:
replayfaqs.com @ web.archive.org
Also, check the links in the next couple of posts in this thread to see if there's an existing thread that covers the topic in question.
Options for continuing to use ReplayTV
1. VCR Mode - use Manual Record.
2. LaHo - switch to LaHo - cost $21/6 months for 1 unit, $12/6 months each additional unit.
http://www.percdata.com/
2. WiRNS & Schedules Direct - cost $25/year - all units
http://wirns.com/
http://schedulesdirect.org/
Thanks!!!
Later, Rob
Select a link for questions on: Remotes, JP1, JP1 Forums
I prefer emails to PMs, my email is rob1 (at) rockabilly (dot) net
The Robman is offline
post #2 of 7 Old 12-16-2004, 10:08 AM - Thread Starter
The Robman's Avatar
Quoted: 45 Post(s)
A. Remote Control Issues
1. How to control multiple Replays in the same location
2. Universal Remote for ReplayTV
3. Worn Out SELECT button
4. ReplayEric's original thread about the 3.0 software
5. Philips DVR remote
6. Replay Remote - Audio hack
7. Universal Cable Boxes
8. Replay remote no longer works Replay
B. Hacking Items
1. Adding new IR Blaster codes to the Replay (4k/5k)
2. Adding new IR Blaster codes to the Replay (2k/3k)
3. Find hidden local numbers
C. Replay Drive Images
1. Drive Image Server
2. FTP server image thread
If you find other threads that are useful in answering FAQs, post them here.
Later, Rob
post #3 of 7 Old 12-16-2004, 11:14 AM
ClearToLand's Avatar
Quoted: 34 Post(s)
Liked: 41
PLEASE DO NOT REPLY TO THIS THREAD!
[Send me a PM; Start a new thread; etc... Thanks!]
This is a "Work-in-Progress" Document!
  1. DHCP Server / ReplayTV Dual IP Bug (2004) - sfhub
    DHCP Server / ReplayTV Dual IP Bug Revisited (2005) - sfhub
  2. "Please wait" failure modes other than HD - dstoffa
  3. Duplicate ISN Problem - j.m.
  4. 5xxx IR Receiver Alignment - ClearToLand
  5. Please Help: DirecTV Receiver D10-200 (D10-300) - stern_keefer
    Fix For D10-100 Local Channel Changing Problem - DosMan
    ReplayTV using serial link w/newer DirecTV receivers - DosMan - Web Page
    ReplayTV KnowledgeBase Article: "Which satellite receivers support serial control?" - DosMan
    DirecTV Satellite Receivers Compatible With ReplayTV Serial Data Link - rm -rf *.*
  6. Pictures of 5000 Series On-Screen Displays - Loren Kruse.
  7. 4000 vs. 5000 Series Differences - Paul Bruneau
  8. TiVo Series 2 vs. ReplayTV 5000 Comparison - ClearToLand
  9. ReplayTV Software Descriptions & Links [Major] - f2000Keith
    ReplayTV Software Accessories & Add-Ons [Minor] - ClearToLand
  10. FTP Image Server - Ghoul
  11. Re-route ReplayTV IDE Cable to Improve Airflow - icecow
  12. Multiple Replay Scheduling for the Methodically Challenged - ClearToLand
  13. THEME-Based Recording Priorities - Various
  14. No Dups and Overflow... - ClearToLand
  15. Pushing Weather Radar Photos to ReplayTV via DVArchive - herbert
  16. Multiple ReplayTV, a Modem and a Crossover Cable - Various
  17. Voluntary collective study on ReplayTV ZONES codes (for a better FAQ) - icecow
    Voluntary collective study on ReplayTV ClawFoot Portal functions (for a better FAQ) - icecow
    Wayback Machine: Replay FAQs - What can I enter in the Claw Foot Portal?
    Molehill Twiki Mirror - Clawfoot Commands - Todd Larason
  18. No fuss 50xx Harddrive Upgrade for determined newbies - icecow
    $80 Out-of-Warranty Factory Repair *OR* D-I-Y HD Upgrade? - ClearToLand
  19. Configuring Remotes For Multiple ReplayTVs in One Physical Location - Various
    How to control multiple Replays in the same location - Various
    How To Run 2-4 Replays Individually From One Replay Remote - drlava
    URC-6131 & Advanced Programming *WITHOUT* JP1 - ClearToLand
  20. Using Extract_RTV on 4xxx and 5xxx Drives - FlipFlop
    Is There a Way to Copy a New Image, But Keep the Existing Mpeg Partition? - FlipFlop
  21. Avoid Interrupting a Disk Write When Performing a COLD BOOT - ClearToLand
  22. Simple fix for some of the infinite reboot problems... - Jeff D
  23. Reverting to Your Previous Software Build - j.m.
  24. Setting Up WiRNS to Preserve CA/IVS on a 55XX - moyekj
  25. Perl Script - WiRNS Initiated Net Connect - moyekj
    Workaround for 5xxx failure to reboot every 7 days? - j.m.
  26. Channel Guide Updates Only Next 24 Hours for Program Changes - barmar
  27. First Connect via Modem After Initial Setup via Broadband Bug - sfhub
    Finding *FREE* (aka non-LD) Dial-Up / Modem Telephone Numbers - Mikeyboy
  28. Troubleshooting ReplayTV's 2 HTTP Servers - sfhub
  29. Modem-Only ReplayTV Connects via Broadband Through PC - richardtallent
  30. How to Revive a Seemingly Dead ReplayTV Tuner - Crunchy Doodle
  31. How Exactly Does "Commercial Advance" Work? - Various
    Does Show|Nav Use the Same Marker Reference Points as Commercial Advance? - Various
    Commercial Advance Patents
  32. List of things that screw with 2.4 GHz WiFi-B, G - SMMinke
  33. 50xx/55xx Series Pixilating, Skipping, Locking Up and Re-Booting - Mikeyboy
  34. Current GetShellCommands - ClearToLand
  35. Current PTVIO ReplayTV Shell Commands - Sean Riddle
    Activating PTVIO - j.m.
  36. ReplayTV Twiki - Todd Larason
  37. ReplayTV Disk Fragmentation (or the lack of) - Various
  38. ReplayTV 5XXX Reboot Troubleshooting Checklist - ClearToLand
  39. How to Repair a Corrupt Configuration File *WITHOUT* Resorting to 382-Zones 'Factory Reset' - odie34
  40. "Setting the Clock..." *DOESN'T* If the DNS Lookup Fails - empyle
  41. Remote ReplayTV Guide(s) Sporadically Don't Refresh - hdonzis
  42. Selecting 'Content Skip' Mode (the opposite of 'Commercial Skip') - CCCP
  43. Unexpected Error 93A6000B - Replays and Transparent Proxies - sfhub
  44. Disappearing ReplayTVs? Give Them Their Own Subnet/VLAN! - rkramer
    Intermittently Losing Connectivity Until I 243-Zones/17... - gerry_duprey
    Running an UNKNOWN, Possibly OUT OF DATE version of DVArchive - gerry_duprey
  45. [How-Do-I] Control My NEW OTA / CABLE Digital STB With My OLD ReplayTV? - ClearToLand
  46. My ReplayTV Reboots When Scrolling Through the Channel Guide - RSaunders
  47. ReplayTV Knowledge Base: How do I adjust or tune the IR code settings for my cable or satellite box? - ClearToLand
  48. Wayback Machine: ReplayTV Find Answer - jlv
  49. Wayback Machine: ReplayTV Knowledgebase - jlv
  50. Wayback Machine: Replay FAQs - jleavens
  51. Wayback Machine: Molehill.Org - TWiki.Replay - Todd Larason
  52. Womble, Replaytv output and DVD burning - Various
    Jim's Tips: ReplayTV Tip #1-ReplayTV to DVD HOWTO
  53. How to server WiRNS guide data to DVArchive? - Various
  54. WiRNs and Schedules Direct - Various
    ~~~~~Demarcation Line~~~~~
  55. ASCII Character Equipment Layout Diagram Revisited - TheDreamer (Sorry Max - Lawrence's diagram is GORGEOUS - for ASCII that is)
    ASCII Character Equipment Layout Diagram - MaxH (When a newbie can't verbally explain their wiring layout, have them edit Max's diagram in Notepad and re-post)
  56. Quickest way I've found to do a search on AVS - icecow
    Effective SEARCH Techniques... - ClearToLand
  57. Posting and You - A Multimedia Guide for Newcomers to Forums - ClearToLand
  58. How to Ask Questions "The Smart Way" - ClearToLand
  59. MAJOR (IMO) ReplayTV "Events" That Have Been "Passed Over"... - ClearToLand
  60. Google Search Operators - Google Guide
  61. ClearToLand's Panasonic DVDR Tips - ClearToLand (This LINK, located here, is just a 'shortcut' for me)
  62. .
49507 Views - 05/14/2012 @ 05:18 [FAQ]
48052 Views - 01/02/2012 @ 23:15 [FAQ]
46180 Views - 07/15/2011 @ 14:00 [FAQ]
43093 Views - 09/07/2010 @ 18:45 [FAQ]
38855 Views - 09/21/2009 @ 20:10 [FAQ]
30831 Views - 05/18/2008 @ 15:55 [FAQ]
28220 Views - 12/30/2007 @ 14:30 [FAQ]
17002 Views - 04/15/2006 @ 19:44 [FAQ]
15140 Views - 01/29/2006 @ 16:10 [FAQ]
13312 Views - 12/05/2005 @ 12:55 [FAQ]
11115 Views - 10/07/2005 @ 00:50 [FAQ]
09636 Views - 08/20/2005 @ 17:00 [FAQ]
00481 Views - 12/23/2004 @ 22:16
Low Post Count <> Low Knowledge ergo High Post Count <> High Knowledge
ClearToLand's Picks For Best Answers to Common ReplayTV Questions
Remember, it's only TV...
ClearToLand is offline
post #4 of 7 Old 05-27-2005, 07:42 AM - Thread Starter
The Robman's Avatar
Quoted: 45 Post(s)
bump to save from archive
Later, Rob
post #5 of 7 Old 09-30-2005, 03:03 PM
Quoted: 34 Post(s)
Liked: 41
BUMP to prevent archiving...
post #6 of 7 Old 07-26-2015, 03:47 PM
SD_Shadow's Avatar
Originally Posted by lclarkrtv View Post
I didn't check all of them, but of about 10 FAQ links I clicked on, all but two of them produced this 404 error:
Not Found
The requested URL /avs-vb/showthread.php was not found on this server.
Does anyone have the knowhow and power to fix them?
Just reply here.
Sent from my XT1028 using Tapatalk
SD_Shadow is offline
post #7 of 7 Old 07-26-2015, 05:38 PM
Quoted: 34 Post(s)
Liked: 41
Unhappy Time Moves On...
Originally Posted by SD_Shadow View Post
Just reply here.
OK.
...Does anyone have the knowhow and power to fix them?
The owners of the sites the LINKs point to have the knowhow and power.
If you hover your mouse pointer over a LINK, you'll see the URL. Many LINKs point to either:
A decade ago, when many of those LINKs were first created, this forum ran on vBulletin software. For some reason that I believe was related to disk storage problems, the owners decided to split off inactive messages falling within two date ranges into two separate URLs. If you click on the two LINKs above, you'll see that the URLs still exist, but, vBulletin is no longer running to allow access to the data, if it even exists.
If you click on the two LINKs below:
you'll see the oldest Index Pages for those LINKs that are available on the Wayback Machine (GOOGLE it to find out more about it). Unfortunately, they appear to be the only pages the owners, avsforum, allowed to be saved.
If you click on LINKs 48-51, you'll see the actual data since THEIR owners DID allow the Wayback Machine access.
Time moves on...
bri4jenn and SD_Shadow like this.
Reply ReplayTV & Showstopper PVRs
