OT: Buffalo WBR-G54 and port forwarding - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 03-18-2005, 11:50 AM - Thread Starter
moyekj's Avatar
There have been many cases when I want to open up ports in the router for a limited amount of time. With the WBR-G54s and firmware rev I currently have there seems to be no way to selectively enable/disable entries. To disable a specific port forwarding you have to delete the entry. This makes it a pain when later on you need that port forwarding again and you have to re-add the entry, especially if there are a lot of them.
Anyone found a good way to deal with this? Maybe latest versions of the firmware already have this capability?
-Kevin
TiVo 6 tuner Roamio Pro, Elite & Premiere + MoCA networking.
kmttg - Tivo To Go and Advanced Remote Control
moyekj is offline
Closed Thread ReplayTV & Showstopper PVRs
