WiRNS 1.3.2 - Page 4 - AVS Forum | Home Theater Discussions And Reviews
post #91 of 183 Old 06-09-2006, 09:20 PM
joecool335's Avatar
Hi,
Not sure if this is the correct place to post but... just wanted to know. Is it possible to use other guides that zap2it I would like to use titantv there channel list is much more accurate and never expires. Just wondering...if there is a way would it be very complicated.
Joe
joecool335 is offline
post #92 of 183 Old 06-11-2006, 12:54 PM - Thread Starter
rbolen70's Avatar
Originally Posted by joecool335 View Post
Hi,
Joe
Joe,
For now, it's just Zap2it and xmltv. Maybe in the future, but who knows.
Ryan
rbolen70 is offline
post #93 of 183 Old 06-16-2006, 02:49 PM - Thread Starter
rbolen70's Avatar
1.3.2.13 Posted
Happy Weekend!
Go to http://www.wirns.com and go to "Just lemme download" near the bottom
OR
If you have 1.3.1.26+ installed, get the latest WiRNSMon with the Updater fixes here: WiRNSMon.exe
Then, select "Check for Updates".
1.3.2.13 6/16/2006
WiRNS
1. Add vacation notice to upload to Poopli/IVSBase instead of showlist - via IVS config page.
2. Re-implement Glenn's process queuing.
3. Prevent guide update from happening when todo is running.
4. Added support for Zone recordings in ToDo. Most accurate when using WiRNS guide data. ** can add a LOT of overhead, depending on the zone **
5. Tune ToDo conflict determination.
6. Add more menu options to WiRNSMon.
7. Disable ToDo Zones via ToDoZones regkey.
8. Play shows via web from ReplayGuide pop-up window.
9. Work on IVSBase email processing.
10. Added Play button.
11. Prevent more than one WiRNSmon.exe from running.
12. Default setting for ToDo zones to false in the registry.
13. Use VLC's ActiveX plugin for over-the-WAN transcoding. http://nightlies.videolan.org/build/...20060520-0000/
14. Fix marking downloaded shows on the ReplayGuide page.
15. Add CA support for moyekj's version of VLC.
16. Fix marking duplicate shows on the ReplayGuide page.
17. Add Rebuild ReplayGuide for replays on menu and WiRNSMon.
For more, see changelog.txt...
WiRNS is now classified as closed-source FreeWare.
License
rbolen70 is offline
post #94 of 183 Old 06-17-2006, 03:39 PM
Synapse's Avatar
I had some trouble getting this new version working under a new install of XP (sp2 w/updates)... but I assume I screwed up the config. Anyway, I am happy to report that I have a successful install of wirns on the new beta 2 of Vista! However, it is the 1.3.2.12 version.
Synapse is offline
post #95 of 183 Old 06-30-2006, 10:43 AM - Thread Starter
rbolen70's Avatar
1.3.2.14 Posted
Happy Holiday Weekend!
OR
1.3.2.14 6/30/2006
WiRNS
1. Fix issue with ProxyRequest (many plugins).
2. Add IVSm support for proxies.
3. Consolodate ProxyRequest.
4. Fix show sending/proxying via IVSTracker.
5. Broke out Exe & Dll from WiRNS.exe.
6. Fix WiRNSMon.pdb updating.
7. SQLite 3.3.6.
8. Gzip viewlog & index.
9. Log web access for skip/successful/fail logins.
10. Adjust http timeouts.
License
rbolen70 is offline
post #96 of 183 Old 08-04-2006, 12:42 PM - Thread Starter
rbolen70's Avatar
1.3.2.15 Posted
Happy Weekend!
Go to WiRNS.com and go to "Just lemme download" near the bottom
OR
1.3.2.15 8/04/2006
WiRNS
1. Catch header exceptions when proxying requests.
2. Fix Dish PPV listings.
3. Add event trigger after JIT scheduling.
4. Don't check DVA for ivs info during discovery.
5. Consolidate array lists to save memory.
6. Add slider select bar for IVS Throttle Rate.
7. Fix menu double-click issue.
8. Log show requests for play/download.
License
rbolen70 is offline
post #97 of 183 Old 08-27-2006, 06:29 PM
strangel's Avatar
I thought I saw a guide on how to do it once before, but i can't find it now- has anyone done this? Is it possible? WiRNS spends ALOT of time pegging my CPU and I'm assuming it's the SQL engine. I have a SQL server here that doesn't do much for me but should easily be able to handle the WiRNS load if a conversion if possible.
Jim
strangel is offline
post #98 of 183 Old 08-29-2006, 11:08 AM - Thread Starter
rbolen70's Avatar
Not anymore. You might be thinking about the 0.7x version.
Sqlite is hard-coded into the app.
Ryan
rbolen70 is offline
post #99 of 183 Old 08-31-2006, 04:44 AM
Bigjohns's Avatar
wins has been crashing every day on me since the last update. Don't know exactly whats causing it - just getting messages in the event log "the wirns service has terminated unexpectedly... it has done this 4 times. Action taken - service restarted"
Bigjohns is offline
post #100 of 183 Old 08-31-2006, 11:15 AM - Thread Starter
rbolen70's Avatar
What's in the wirns.log and wirns.debug.log when it crashes?
Ryan
rbolen70 is offline
post #101 of 183 Old 08-31-2006, 07:08 PM
Bigjohns's Avatar
I just installed the latest update... so, I'll have a look if it does it again - it just 'locked up'. The wirns mon showed it OK, but would not restart it... the service died.
Now I'm getting odd messages trying to send via WIRNS...
Show: Eureka - Blink (1156910700) sent from sxxxxx88 to 00004-xxxxx-52970 failed.
Remote Replay info:
ISN: 00004-xxxxx-52970 IP: 00004-xxxxx-52970 Port: 29001
why would it show the IVS as the IP?
Bigjohns is offline
post #102 of 183 Old 09-01-2006, 04:14 AM
Bigjohns's Avatar
Wirns is using 99%CPU...
Seems to be working, in the background anyway - here is the log.
Code:
9/1/2006 05:07:57] [DNS] Using file: C:\\WiRNS\\Plugins\\IVSProvider.hosts
[9/1/2006 05:07:57] [DNS] Returning 67.41.76.188 for rddns-production-1.replaytv.net to 192.168.2.52
[9/1/2006 05:13:03] [DNS] Using file: C:\\WiRNS\\Plugins\\IVSProvider.hosts
[9/1/2006 05:13:03] [DNS] Returning 67.41.76.188 for rddns-production-1.replaytv.net to 192.168.2.41
[9/1/2006 05:41:20] [DNS] Using file: C:\\WiRNS\\Plugins\\IVSProvider.hosts
[9/1/2006 05:41:20] [DNS] Returning 66.92.130.50 for rddns-production-2.replaytv.net to 192.168.2.51
[9/1/2006 06:06:26] Bad File: I:\\DVArchive\\Local_guide\\Lost - ... And Found.xml
[9/1/2006 06:06:30] Bad File: e:\\DVarchive\\Local_guide\\Stargate SG-1 - Flesh and Blood.xml
[9/1/2006 06:06:32] Bad File: J:\\dvarchive\\Tru Calling - In the Dark.xml
[9/1/2006 06:06:36] Bad File: J:\\dvarchive\\Battlestar Galactica - Tigh Me Up- Tigh Me Down.xml
[9/1/2006 06:07:58] [DNS] Using file: C:\\WiRNS\\Plugins\\IVSProvider.hosts
[9/1/2006 06:07:58] [DNS] Returning 67.41.76.188 for rddns-production-1.replaytv.net to 192.168.2.52
[9/1/2006 06:13:03] [DNS] Using file: C:\\WiRNS\\Plugins\\IVSProvider.hosts
[9/1/2006 06:13:03] [DNS] Returning 67.41.76.188 for rddns-production-1.replaytv.net to 192.168.2.41
[9/1/2006 06:41:21] [DNS] Using file: C:\\WiRNS\\Plugins\\IVSProvider.hosts
[9/1/2006 06:41:21] [DNS] Returning 66.92.130.50 for rddns-production-2.replaytv.net to 192.168.2.51
[9/1/2006 07:06:27] Bad File: e:\\DVarchive\\Local_guide\\Eureka - Pilot.xml
[9/1/2006 07:06:27] Bad File: J:\\dvarchive\\Rescue Me - Mom.xml
[9/1/2006 07:06:28] Bad File: J:\\dvarchive\\Star Trek- Enterprise - Terra Prime.xml
[9/1/2006 07:06:29] Bad File: J:\\dvarchive\\Star Trek- Enterprise - Terra Prime.xml
[9/1/2006 07:06:29] Bad File: J:\\dvarchive\\Star Trek- Enterprise - The Aenar.xml
[9/1/2006 07:06:29] Bad File: J:\\dvarchive\\24 - Day 3- 5-00PM - 6-00PM.xml
[9/1/2006 07:06:29] Bad File: J:\\dvarchive\\Star Trek- Enterprise.xml
[9/1/2006 07:06:29] Bad File: J:\\dvarchive\\24 - Day 3- 7-00PM - 8-00PM.xml
[9/1/2006 07:06:41] Bad File: J:\\dvarchive\\Battlestar Galactica - Water.xml
[9/1/2006 07:07:58] [DNS] Using file: C:\\WiRNS\\Plugins\\IVSProvider.hosts
[9/1/2006 07:07:58] [DNS] Returning 67.41.76.188 for rddns-production-1.replaytv.net to 192.168.2.52
but I'm concerned about it finding all these bad XML files?!
And it's web interface is not responding.
Wirns mon shows GREEN
Here is debug:
Code:
9/1/2006 06:06:36] GetGuide(): System.IO.IOException: The process cannot access the file "J:\\dvarchive\\Battlestar Galactica - Tigh Me Up- Tigh Me Down.xml" because it is being used by another process.
   at System.IO.__Error.WinIOError(Int32 errorCode, String str)
   at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, Boolean useAsync, String msgPath, Boolean bFromProxy)
   at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share)
   at System.Xml.XmlDownloadManager.GetStream(Uri uri, ICredentials credentials)
   at System.Xml.XmlUrlResolver.GetEntity(Uri absoluteUri, String role, Type ofObjectToReturn)
   at System.Xml.XmlTextReader.CreateScanner()
   at System.Xml.XmlTextReader.Init()
   at System.Xml.XmlTextReader.Read()
   at WiRNS.WiRNSMain.GetGuideInfo(Boolean refresh, Int32 rtvVer) in d:\\CVS\\WiRNS\\WiRNS\\WiRNSMain.cs:line 3685
[9/1/2006 07:06:27] GetGuide(): System.IO.IOException: The process cannot access the file "e:\\DVarchive\\Local_guide\\Eureka - Pilot.xml" because it is being used by another process.
[9/1/2006 07:06:27] GetGuide(): System.IO.IOException: The process cannot access the file "J:\\dvarchive\\Rescue Me - Mom.xml" because it is being used by another process.
[9/1/2006 07:06:28] GetGuide(): System.IO.IOException: The process cannot access the file "J:\\dvarchive\\Star Trek- Enterprise - Terra Prime.xml" because it is being used by another process.
[9/1/2006 07:06:29] GetGuide(): System.IO.IOException: The process cannot access the file "J:\\dvarchive\\Star Trek- Enterprise - Terra Prime.xml" because it is being used by another process.
[9/1/2006 07:06:29] GetGuide(): System.IO.IOException: The process cannot access the file "J:\\dvarchive\\Star Trek- Enterprise - The Aenar.xml" because it is being used by another process.
[9/1/2006 07:06:29] GetGuide(): System.IO.IOException: The process cannot access the file "J:\\dvarchive\\24 - Day 3- 5-00PM - 6-00PM.xml" because it is being used by another process.
[9/1/2006 07:06:29] GetGuide(): System.IO.IOException: The process cannot access the file "J:\\dvarchive\\Star Trek- Enterprise.xml" because it is being used by another process.
[9/1/2006 07:06:29] GetGuide(): System.IO.IOException: The process cannot access the file "J:\\dvarchive\\24 - Day 3- 7-00PM - 8-00PM.xml" because it is being used by another process.
[9/1/2006 07:06:41] GetGuide(): System.IO.IOException: The process cannot access the file "J:\\dvarchive\\Battlestar Galactica - Water.xml" because it is being used by another process.
of course, that's not the full log...
Bigjohns is offline
post #103 of 183 Old 09-01-2006, 06:18 AM - Thread Starter
rbolen70's Avatar
I'm wondering if DVArchive has those files open at that time while scanning for it's guide update.
Ryan
rbolen70 is offline
post #104 of 183 Old 09-01-2006, 07:40 AM
Bigjohns's Avatar
I don't know why it would... dvarchive is not at the time serving any shows...
Update: Wirns seems to be doing it's thing in the background, but the web-server is not working at all. Trying to RESTART wirns from the wirns mon ends up hanging the service, and a reboot of the PC is necessary...
John
Bigjohns is offline
post #105 of 183 Old 09-01-2006, 01:18 PM - Thread Starter
rbolen70's Avatar
1.3.2.16 Posted
Happy Weekend!
OR
1.3.2.16 9/01/2006
WiRNS
1. View wirns.log and wirns.debug.log via gui window from WiRNSMon.
2. In web view log, don't worry about debug.log if empty or non-existent.
3. Fix VLC Streaming.
4. Allow quote and apostrophe use in mouse-over text.
5. Improvements to gui log viewer.
6. Hide lineup selections for DVA & WiRNS Replays.
7. Re-implement filesystem watcher for show paths. WiRNS will create a new .guide whenever there is a change.
8. Auto-update log tabs in the gui-based log viewer.
9. Option to publish received shows on Poopli/IVSBase on a per replay basis.
License
rbolen70 is offline
post #106 of 183 Old 09-01-2006, 03:50 PM
Bigjohns's Avatar
Lets see if this one exhibits the same problem...
but - I can't seem to send any more. I try to send, and I get a nearly immediate 'red' screen. The device I'm trying to send to passes the IVS test.
this is what is logged:
9/1/2006 18:41:21] [DNS] Using file: C:\\WiRNS\\Plugins\\IVSProvider.hosts
[9/1/2006 18:41:21] [DNS] Returning 67.41.76.188 for rddns-production-1.replaytv.net to 192.168.2.51
[9/1/2006 18:48:48] [IVSPROVIDER] Getting backup.rddns.cc for rddns-production.replaytv.net
[9/1/2006 18:48:48] [PLUGIN] IVSProvider returned RDDNS information for ISN 00004-54831-52970
Bigjohns is offline
post #107 of 183 Old 09-01-2006, 04:48 PM - Thread Starter
rbolen70's Avatar
I just tried it to verify and it worked.
Ryan
rbolen70 is offline
post #108 of 183 Old 09-01-2006, 08:38 PM
Bigjohns's Avatar
it worked the third time I tried it. Odd.
Let's see if I can get through the night without crashing it!
John
Bigjohns is offline
post #109 of 183 Old 09-01-2006, 08:59 PM
Bigjohns's Avatar
I just don't understand it... the 'webserver' crashed again... I can't make it load the web page, or refresh anything... firefox just sits there 'loading' over and over and over..
Does it matter than I'm runnign win2k (all service packs and updates) on a dual core A64 processor?
John
ryan - you've fixed it remotely for me before, so you might have the login information still... give it a try. You won't be able to connect, I expect, even though the log is updating and everything there seems normal.
Bigjohns is offline
post #110 of 183 Old 09-02-2006, 11:27 AM
Bigjohns's Avatar
Trying to stop/start the service from command line:
Code:
C:\\Documents and Settings\\Administrator>net stop wirns
The service could not be controlled in its present state.
More help is available by typing NET HELPMSG 2189.
C:\\Documents and Settings\\Administrator>net start wirns
The requested service has already been started.
More help is available by typing NET HELPMSG 2182.
Bigjohns is offline
post #111 of 183 Old 09-02-2006, 08:58 PM
Bigjohns's Avatar
Just the oddest stuff...
Code:
Show: 2006 MTV Video Music Awards - (1157068797) sent from Stegj30188 to 00004-54831-84915 failed.
Remote Replay info:
RDDNS Server up; ISN not found
but the unit passes the IVS test...
Bigjohns is offline
post #112 of 183 Old 09-03-2006, 04:56 AM
Bigjohns's Avatar
When a show is 'green' in the guide, that means it's copied to the wirns download directories, right? Safe to delete from the replay?
Bigjohns is offline
post #113 of 183 Old 09-03-2006, 10:39 AM - Thread Starter
rbolen70's Avatar
There was an issue with my backup rddns server. Got this fixed. When I copied over the updated plugins, I copied over a hosts file that simulated a DNNA server outage. So, any lookups for isn's not known to the backup, would fail.
Ryan
rbolen70 is offline
post #114 of 183 Old 09-03-2006, 11:29 AM
Bigjohns's Avatar
Cool.
Wirns 'webserver' crashed on me again. Looking at the wirns webpage, which I leave constantly open, it shows the last RDNS status at 11:17:13am.
Clicking on anything causes firefox to try to connect... but it just tries constantly...
here is the current WIRNS log:
Code:
9/3/2006 10:50:35] Configured to refresh ToDo and Replay Guide every 120 minutes.
[9/3/2006 11:09:42] [DNS] Using file: C:\\WiRNS\\Plugins\\IVSProvider.hosts
[9/3/2006 11:09:42] [DNS] Returning 192.168.2.110 for rddns-production.replaytv.net to 192.168.2.52
[9/3/2006 11:09:42] [PLUGIN] IVSProvider received an update request from ISN 00004-54832-57421
[9/3/2006 11:09:42] [IVSPROVIDER] Getting backup.rddns.cc for rddns-production.replaytv.net
[9/3/2006 11:13:12] [DNS] Using file: C:\\WiRNS\\Plugins\\IVSProvider.hosts
[9/3/2006 11:13:12] [DNS] Returning 192.168.2.110 for rddns-production.replaytv.net to 192.168.2.41
[9/3/2006 11:13:12] [PLUGIN] IVSProvider received an update request from ISN 00004-54831-85021
[9/3/2006 11:13:12] [IVSPROVIDER] Getting backup.rddns.cc for rddns-production.replaytv.net
[9/3/2006 11:16:50] Saving configuration
[9/3/2006 11:16:50] New configuration saved.
[9/3/2006 11:16:50] Loading configuration
[9/3/2006 11:17:12] [IVSPROVIDER] Getting backup.rddns.cc for rddns-production.replaytv.net
[9/3/2006 11:17:13] [IVSPROVIDER] Getting backup.rddns.cc for rddns-production.replaytv.net
[9/3/2006 11:17:13] [PLUGIN] IVSProvider returned RDDNS information for ISN 00004-54831-85021
[9/3/2006 11:41:26] [DNS] Using file: C:\\WiRNS\\Plugins\\IVSProvider.hosts
[9/3/2006 11:41:26] [DNS] Returning 192.168.2.110 for rddns-production.replaytv.net to 192.168.2.51
[9/3/2006 11:41:26] [PLUGIN] IVSProvider received an update request from ISN 00004-54831-88325
[9/3/2006 11:41:26] [IVSPROVIDER] Getting backup.rddns.cc for rddns-production.replaytv.net
[9/3/2006 12:09:42] [DNS] Using file: C:\\WiRNS\\Plugins\\IVSProvider.hosts
[9/3/2006 12:09:42] [DNS] Returning 192.168.2.110 for rddns-production.replaytv.net to 192.168.2.52
[9/3/2006 12:09:42] [PLUGIN] IVSProvider received an update request from ISN 00004-54832-57421
[9/3/2006 12:09:42] [IVSPROVIDER] Getting backup.rddns.cc for rddns-production.replaytv.net
[9/3/2006 12:13:12] [DNS] Using file: C:\\WiRNS\\Plugins\\IVSProvider.hosts
[9/3/2006 12:13:12] [DNS] Returning 192.168.2.110 for rddns-production.replaytv.net to 192.168.2.41
[9/3/2006 12:13:12] [PLUGIN] IVSProvider received an update request from ISN 00004-54831-85021
[9/3/2006 12:13:12] [IVSPROVIDER] Getting backup.rddns.cc for rddns-production.replaytv.net
[9/3/2006 12:41:26] [DNS] Using file: C:\\WiRNS\\Plugins\\IVSProvider.hosts
[9/3/2006 12:41:26] [DNS] Returning 192.168.2.110 for rddns-production.replaytv.net to 192.168.2.51
[9/3/2006 12:41:26] [PLUGIN] IVSProvider received an update request from ISN 00004-54831-88325
[9/3/2006 12:41:26] [IVSPROVIDER] Getting backup.rddns.cc for rddns-production.replaytv.net
[9/3/2006 12:50:35] Updating ReplayGuide information
[9/3/2006 12:50:35] Stopping ToDo Timer
[9/3/2006 12:50:35] Processing ReplayGuide Information.
[9/3/2006 12:50:37] Refreshing RecordingGuide for: Bed Room(192.168.2.41)
[9/3/2006 12:50:39] Parsed 40/40 entries.
[9/3/2006 12:50:39] Refreshing RecordingGuide for: Bre Rtv(192.168.2.52)
[9/3/2006 12:50:40] Parsed 52/52 entries.
[9/3/2006 12:50:40] Refreshing RecordingGuide for: Family Room(192.168.2.51)
[9/3/2006 12:50:43] Parsed 102/102 entries.
[9/3/2006 12:50:43] Refreshing RecordingGuide for: jcs-win2k(192.168.2.110)
[9/3/2006 12:50:44] Parsed 50/50 entries.
[9/3/2006 12:50:46] Added 88 ReplayGuide shows for Bed Room
[9/3/2006 12:50:47] Added 128 ReplayGuide shows for Bre Rtv
[9/3/2006 12:50:49] Added 261 ReplayGuide shows for Family Room
[9/3/2006 12:50:51] Added 539 ReplayGuide shows for jcs-win2k
[9/3/2006 12:50:58] ReplayGuide data for Bed Room successfully uploaded to Poopli.
[9/3/2006 12:51:02] ReplayGuide data for Bre Rtv successfully uploaded to Poopli.
[9/3/2006 12:51:07] ReplayGuide data for Family Room successfully uploaded to Poopli.
[9/3/2006 12:51:20] ReplayGuide data for jcs-win2k successfully uploaded to Poopli.
[9/3/2006 12:51:29] Checking Manual Recordings.
[9/3/2006 12:51:29] Added 1 Manual Recordings to the database.
[9/3/2006 12:51:29] Scheduling JIT Recordings
[9/3/2006 12:51:29] Scheduling JIT Recordings complete
[9/3/2006 12:51:29] Processing ToDo Information.
[9/3/2006 12:51:29] Building ToDo List for: Bed Room
[9/3/2006 12:51:29] Added 16 ToDo entries for Bed Room in 0.3281313 seconds.
[9/3/2006 12:51:29] Building ToDo List for: Bre Rtv
[9/3/2006 12:51:30] Added 17 ToDo entries for Bre Rtv in 0.3437566 seconds.
[9/3/2006 12:51:30] Building ToDo List for: Family Room
[9/3/2006 12:51:30] Added 16 ToDo entries for Family Room in 0.2343795 seconds.
[9/3/2006 12:51:30] Determining conflicts...
[9/3/2006 12:51:30] Completed conflict determination in 0.0468759 seconds.
[9/3/2006 12:51:30] Done.
[9/3/2006 12:51:30] Configured to refresh ToDo and Replay Guide every 120 minutes.
[9/3/2006 13:09:42] [DNS] Using file: C:\\WiRNS\\Plugins\\IVSProvider.hosts
[9/3/2006 13:09:42] [DNS] Returning 192.168.2.110 for rddns-production.replaytv.net to 192.168.2.52
[9/3/2006 13:09:42] [PLUGIN] IVSProvider received an update request from ISN 00004-54832-57421
[9/3/2006 13:09:42] [IVSPROVIDER] Getting backup.rddns.cc for rddns-production.replaytv.net
[9/3/2006 13:13:12] [DNS] Using file: C:\\WiRNS\\Plugins\\IVSProvider.hosts
[9/3/2006 13:13:12] [DNS] Returning 192.168.2.110 for rddns-production.replaytv.net to 192.168.2.41
[9/3/2006 13:13:13] [PLUGIN] IVSProvider received an update request from ISN 00004-54831-85021
[9/3/2006 13:13:13] [IVSPROVIDER] Getting backup.rddns.cc for rddns-production.replaytv.net
[9/3/2006 13:41:26] [DNS] Using file: C:\\WiRNS\\Plugins\\IVSProvider.hosts
[9/3/2006 13:41:26] [DNS] Returning 192.168.2.110 for rddns-production.replaytv.net to 192.168.2.51
[9/3/2006 13:41:36] [DNS] Using file: C:\\WiRNS\\Plugins\\IVSProvider.hosts
[9/3/2006 13:41:36] [DNS] Returning 67.41.76.188 for rddns-production-1.replaytv.net to 192.168.2.51
[9/3/2006 14:09:42] [DNS] Using file: C:\\WiRNS\\Plugins\\IVSProvider.hosts
[9/3/2006 14:09:42] [DNS] Returning 192.168.2.110 for rddns-production.replaytv.net to 192.168.2.52
[9/3/2006 14:09:52] [DNS] Using file: C:\\WiRNS\\Plugins\\IVSProvider.hosts
[9/3/2006 14:09:52] [DNS] Returning 67.41.76.188 for rddns-production-1.replaytv.net to 192.168.2.52
[9/3/2006 14:13:13] [DNS] Using file: C:\\WiRNS\\Plugins\\IVSProvider.hosts
[9/3/2006 14:13:13] [DNS] Returning 192.168.2.110 for rddns-production.replaytv.net to 192.168.2.41
[9/3/2006 14:13:23] [DNS] Using file: C:\\WiRNS\\Plugins\\IVSProvider.hosts
[9/3/2006 14:13:23] [DNS] Returning 67.41.76.188 for rddns-production-1.replaytv.net to 192.168.2.41
There is nothing in any of the other logs.
Bigjohns is offline
post #115 of 183 Old 09-04-2006, 06:34 AM
Bigjohns's Avatar
One additional odity... my 60 minute shows (dvarchive) show up as 90 minute in WIRNS>...All of them. Not just the ones I have copied recently..
Bigjohns is offline
post #116 of 183 Old 09-06-2006, 06:11 AM
Bigjohns's Avatar
updated info:
I installed an update monday night. No lockup since. But I still have this odd thing where all the shows WIRNS lists from my DVA show as 90 minutes....
Bigjohns is offline
post #117 of 183 Old 09-25-2006, 06:26 AM
meehawl's Avatar
I just did a clean install of WiRNS 1.3.2b15. Twice now it has hung at max CPU usage for several hours. Makes the HTPC incredibly sluggish. Takes a few minutes to respond to a net stop wirns.exe, but eventually does. The common element is that the last WiRNS log entry both times was "Refreshing RecordingGuide" on the DVArchive on the same machine bound to the same NIC using different IP.
Irish guy in New York
meehawl is offline
post #118 of 183 Old 10-06-2006, 12:52 PM - Thread Starter
rbolen70's Avatar
1.3.2.17 Posted
Happy Weekend!
OR
1.3.2.17 10/06/2006
WiRNS
1. Keep bad data from messing up an entire ReplayGuide.
2. Add option to ReplayGuide for case sensitive sorting.
3. Add recorded episode part numbers to JIT / DNRA check.
4. Fix issue with received shows showing up on Poopli/IVSBase if not checked.
5. Add Event Trigger for ReplayTV connected. TheDreamer
6. Add web proxy config.
7. Add option to not use Windows proxy config.
8. Allow "moving" a scheduled recording to a different Replay.
9. Set action to Schedule or Change for a show schedule window based on if the show is already scheduled per replay.
10. Allow user to configure styles for display.
11. Added download satus to What's Happening page.
License
rbolen70 is offline
post #119 of 183 Old 10-15-2006, 06:00 AM
TheOtherAbbot's Avatar
Just wanted to express thanks for keeping this tool up-to-date. Not sure what I'd do without it.
Having said that I do have a request/question and I'm sorry if its been answered previously. Is there anyway to avoid having my guide (in the replay) get messed up around the time that my labs.zap2it.com subscription expires.
Basically, the week after the subscription expires is usually missing 30% of the shows or so and sometimes entire days of everything. I do tricks like adding channels to other devices and then removing them but that doesn't always work.
Is it possible to tell the replay only about the shows that are in the guide so if the changes from the expiration date on are missing then do fill the days with blanks?
TheOtherAbbot is offline
post #120 of 183 Old 10-15-2006, 10:01 AM - Thread Starter
rbolen70's Avatar
Thanks! I'm sure that could be possible, but I want to keep Zap2it data accurate. The message on the index page about subscription expriation shows up around 2 weeks prior to it expiring. If there are blanks, WiRNS does fill them when serving to the Replay.
Ryan
rbolen70 is offline
Reply ReplayTV & Showstopper PVRs
