WiRNS 1.3.2 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 183 Old 10-03-2005, 12:01 PM - Thread Starter
rbolen70's Avatar
WiRNS 1.3.2 Released!
Features:
  • Alternative guide delivery (Canadians, other non-Americans, 4DTV).
  • Supports XMLTV guide data (Canadians, other non-Americans).
  • Configurable channel lineup offsets.
  • Web based channel guide.
  • Low Bandwidth/Dial-up version of Web based channel guide.
  • Web based ReplayGuide - see what's recorded.
  • Web based ToDo list - see what's going to record.
  • Schedule daily/weekly netconnects.
  • Automatic/Manual software updates for WiRNS via WiRNSMon.
  • Service control and many more options via WiRNSMon.
  • Web based scheduling for 4000/5000 users.
  • Download or schedule download of multiple shows to your WiRNS PC.
  • Downloaded shows are DVA compatable (Add your WiRNS shows directory to DVA).
  • Automatic update of your Poopli account for your Replays.
  • UPNP server.
  • Virtual Replay - View your WiRNS ReplayGuide on your Replays.
  • Virtual Replay - Stream downloaded shows to your Replay.
  • Change show recording options.
  • Web page security.
  • Use a secondary web port in case your ISP blocks port 80.
  • Web-based remote control.
  • Automatically grabs Zap2it lineup info and adds to discovered Replays during setup.
  • Support for up to 3 Zap2it accounts = up to 12 channel lineups.
  • Runs as a service on Windows NT/2K/XP.
  • Can run in a hidden window on Windows 9x/ME.
  • Show searching - better than Replay's.
  • PPV Support for DISH Network.
  • Set your own time to update the channel guide.
  • NTP Client for the WiRNS Computer.
  • NTP "server"/proxy.
  • DNS "server"/proxy - local LAN only.
  • Set your own NTP server IP
  • registry setting at HKLM\\SOFTWARE\\WiRNS\\configuration\
    tpip.
  • System tray service monitor/controller for Win9x/ME/NT/2K/XP.
  • Headend Remapper
  • An example remapchan.csv.sample file is included which is already setup for 4DTV.
  • Selective plugin loading via registry HKLM\\SOFTWARE\\WiRNS\\plugins - 1 loads, 0 doesn't load.
  • Support for WiRNS behind NAT router for remote ReplayTV's (see wirns.hosts).
  • "Automagic" (almost) Dish PPV settings.
  • Force a net connect via the WiRNS web page.
  • Grabs a screen-shot of your replay.
  • Control updates/scheduling via MyReplayTV.com.
  • Database integrity validation.
  • Plus too much more to list here.
Included Plugins:
  • j.m.'s GetShellCommands, NoSoftwareUpdate and IVSProvider plugins.
Requires:
Upgrading:
  • Only upgrade 1.3.1.26 and higher..
Where can I get it?
  • Click HERE and go to "Just lemme download" near the bottom and download the latest version.
rbolen70 is offline
post #2 of 183 Old 10-03-2005, 05:56 PM
Bigjohns's Avatar
can I:
1 -flag channels to show "repeat" flag based on first air date> aka USA and SciFi that dont flag anything...
2 - globally say "if the show says it starts at 9:59, it really starts at 10"
John
Bigjohns is offline
post #3 of 183 Old 10-04-2005, 09:59 AM - Thread Starter
rbolen70's Avatar
Originally Posted by Bigjohns View Post
can I:
Not yet. I've looked into this before and don't think that you can tell the Replay this.
John
I may look into this in the future, but in the meantime, the show pop-up window displays the exact start time and you can then use the start early or start late boxes to adjust for that.
Ryan
rbolen70 is offline
post #4 of 183 Old 10-04-2005, 09:05 PM
Bigjohns's Avatar
Ryan -
All you have to do is have an algorithm that looks at the "first aired date" and if it's more than x days ago, manually add the R flag.
As to number 2, can this be used to modify existing records??
John
Bigjohns is offline
post #5 of 183 Old 10-10-2005, 08:47 AM - Thread Starter
rbolen70's Avatar
New feature added...
Use Original Air Date to flag shows as Repeat - "Days for Repeat flag" on the DataDirect config page.
Run the Updater to get this feature.
Ryan
rbolen70 is offline
post #6 of 183 Old 10-10-2005, 03:44 PM - Thread Starter
rbolen70's Avatar
Today's build...
**** Update to 1.3.2 ONLY
DO NOT UPDATE ANY OTHER BUILDS WITH THIS
Right-click on WiRNSMon in the system tray and click "Check for Updates" or "WiRNS Update" under the Adminstration link on the web page.
WiRNSMon will automatically download any new files and restart WiRNS.
If you are running 1.3.2, you can simply stop WiRNS, unzip to your WiRNS folder and start WiRNS.
If you are not running 1.3.2 yet, you must upgrade prior to using this build.
Changes since 1.3.2:
1.3.2.x x/x/2005
WiRNS
1. Added ProgramFlags, PartsRecord and MovieRecord to downloaded shows and served shows. If none exist, default to TV-Rating as only ProgramFlags.
2. Fix record from show search.
3. Added more index page stuff.
4. More ToDo work.
5. Fix xml end tag.
6. Use Original Air Date to flag shows as Repeat - "Days for Repeat flag" on the DataDirect config page.
7. Display IVSMagic transfers on Index page - if IVSMagic is installed on same PC.
rbolen70 is offline
post #7 of 183 Old 10-10-2005, 08:17 PM
Bigjohns's Avatar
Bigjohns is offline
post #8 of 183 Old 10-11-2005, 10:57 AM
chriv's Avatar
Thanks a million! I cannot wait to try this out. This will make the "First Run Only" feature on the Replay actually worth something on networks like Cartoon Netwoork and USA Network.
Once again, thanks a million!
chriv is offline
post #9 of 183 Old 10-18-2005, 04:25 PM - Thread Starter
rbolen70's Avatar
Run the updater & you can now grab screenshots from anywhere that you can get to your WiRNS box.
Ryan
rbolen70 is offline
post #10 of 183 Old 10-21-2005, 03:19 PM - Thread Starter
rbolen70's Avatar
1.3.2.1 Posted
Happy Weekend!
Go to http://wirns.zapto.org and go to "Just lemme download" near the bottom
OR
If you have 1.3.1.26+ installed, get the latest WiRNSMon with the Updater fixes here:
WiRNSMon.exe
Then, select "Check for Updates".
1.3.2.1 10/21/2005
WiRNS
4. More ToDo work.
5. Fix xml end tag.
7. Display IVSMagic transfers on Index page - if IVSMagic is installed on same PC and there are active transfers.
8. The Dreamer's additions to flagging repeats.
9. Updated ZipcodeProvider for local broadcasts - configurable on DataDirect config page.
10. Screenshot from anywhere.
11. Fix problem of Replay rebooting when streaming some shows.
12. Option to leave (HDTV) in description for Poopli updates.
13. cj2's Dish PPV/Daylight savings fix.
For more, see changelog.txt...
****** To reduce zip & msi size, source code has been removed from install and moved to CVS server.
PM me for access with the following:
email address
full name
reason for access
rbolen70 is offline
post #11 of 183 Old 10-23-2005, 09:07 AM
sudhs's Avatar
To All ReplayTV Gurus (Ryan, Kjac etc.)
This is to remind you that though it has been a long time since I logged on to this forum, but all your efforts are very sincerely appreciated by each member of this community. You all have always exceeded our expectations and shown the best of your tech expertise as and when required. Keep up the good work. I very strongly support that WIRNS should now be made public at the CNET website (www.cnet.com).
Ryan, what do you think about it ? Isn't it time that people reconized all you gurus' efforts and make use of this wonderful service. I've come across atleast 2 people who own replaytv but did not know about WIRNS. They were so surprised when I explained the entire stuff to them. I'm sure that if WIRNS goes public, a lot of user base will start using it thereby making it a huge success, as it is now.
JVC HD-P61R1U, BOSE LifeStyle 50, BOSE C-1024 Mod, Audio Auth 1154A Switch, ReplayTV 5504/5040/WIRNS/DVA, Slingbox, PANSAT 2500A, 2700A, DVP642/37 Philips DVD, Panny CP-72 DVD
sudhs is offline
post #12 of 183 Old 10-25-2005, 02:47 PM - Thread Starter
rbolen70's Avatar
sudhs,
Thanks! Maybe soon.
Ryan
rbolen70 is offline
post #13 of 183 Old 10-25-2005, 02:48 PM - Thread Starter
rbolen70's Avatar
Run the updater to get this new feature:
Added multiple show paths. Limit to 5 and separate with ";"s.
ex: d:\\wirns\\shows;D:\\DVArchive\\Local_Guide
I've tested streaming with a network drive as one of the paths and it worked.
Ryan
rbolen70 is offline
post #14 of 183 Old 10-26-2005, 08:59 AM
chriv's Avatar
I absolutely COULD NOT get WiRNS to do a GUIDE UPDATE today. I rolled WiRNS back to a previous version (my backup from the "Backup 2005-10-23 08.49.39" folder), and the guide update appears to be working again.
I can post my log files if you want, but I have a feeling that this might be a problem for everyone who has done the latest update.
You may want to see if you can do a GUIDE UPDATE in the current build of WiRNS. I could not.
chriv is offline
post #15 of 183 Old 10-26-2005, 09:08 AM
Bigjohns's Avatar
Bigjohns is offline
post #16 of 183 Old 10-26-2005, 09:11 AM - Thread Starter
rbolen70's Avatar
Guide problem fixed.
thx.. Ryan
rbolen70 is offline
post #17 of 183 Old 10-26-2005, 09:50 AM
chriv's Avatar
thx.. Ryan
No. Thank you.
chriv is offline
post #18 of 183 Old 10-28-2005, 02:37 PM - Thread Starter
rbolen70's Avatar
1.3.2.2 Posted
Happy Weekend!
OR
If you have 1.3.1.26+ installed, get the latest WiRNSMon with the Updater fixes here: WiRNSMon.exe
1.3.2.2 10/28/2005
WiRNS
1. Made Zap2it Web Timeout message "pretty".
2. Fix streaming shows.
3. Added multiple show paths. Limit to 5 and separate with ";"s.
ex: d:\\wirns\\shows;d:\\D:\\DVArchive\\Local_Guide
4. More identification features for DVA.
5. Added fix for non-existant show path.
6. Final work on replying with replayguide file.
7. Added edit show info.
email address
full name
reason for access
rbolen70 is offline
post #19 of 183 Old 10-28-2005, 07:33 PM
rxman's Avatar
Quoted: 13 Post(s)
don't you sleep?....hehe!
just wanted to thank you for your ongoing development on Wirns...it's great!
still waiting for the ir-port out to start my Mr. Coffee in am...hah!
you work is very much appreciated.
rxman
rxman is offline
post #20 of 183 Old 10-30-2005, 05:19 AM
E_One's Avatar
Does this also means if the disk in one of the path is full, it goes the the next path?
Thanks for the updates.
E_One is offline
post #21 of 183 Old 10-30-2005, 07:33 AM - Thread Starter
rbolen70's Avatar
That's correct.
Ryan
rbolen70 is offline
post #22 of 183 Old 10-30-2005, 11:54 AM
Bigjohns's Avatar
and where in the configuration do we enter these paths? does wirns read/utilize DVArchive data?
Bigjohns is offline
post #23 of 183 Old 10-30-2005, 01:55 PM - Thread Starter
rbolen70's Avatar
WiRNS config page & show path & yes.
Ryan
rbolen70 is offline
post #24 of 183 Old 10-30-2005, 02:27 PM
Bigjohns's Avatar
you mean there:
Code:
Downloaded Shows Directory:
I can type in my DVarchive paths? The local guide paths or the import paths?
Bigjohns is offline
post #25 of 183 Old 10-30-2005, 04:18 PM
lordbry's Avatar
I just stumbled across this message and WiRNS sounds great!
However I couldn't find a web page or other single source of information to tell me all about it, its features, etc. Does anyone have a link for this info or does it not exist?
My best guess about what WiRNS does is that it controls any replay TV's on your network and tells them what to do. So as you can see I need more info! Thanks.
I was going to get plasma... but then I saw the light!
lordbry is offline
post #26 of 183 Old 10-30-2005, 05:24 PM
Bigjohns's Avatar
look at the top message in this thread.
Hey Ryan -
It's not picking up all the files in my DVA directories... like 20 episodes of Battlestar...
Bigjohns is offline
post #27 of 183 Old 10-30-2005, 07:05 PM
l8er's Avatar
Originally Posted by lordbry View Post
However I couldn't find a web page ...
You/re kidding right? Google it first
-Gary
ReplayTV DIY Information/Repair/Upgrade Site: www.replaytvupgrade.com
l8er is offline
post #28 of 183 Old 10-31-2005, 11:41 AM - Thread Starter
rbolen70's Avatar
Hey Ryan -
It should work if you add your Local_Guide path to the shows directory.
Is there anything in the debug.log?
Ryan
rbolen70 is offline
post #29 of 183 Old 10-31-2005, 06:09 PM
Bigjohns's Avatar
Bigjohns is offline
post #30 of 183 Old 10-31-2005, 09:45 PM
Bigjohns's Avatar
Bigjohns is offline
Reply ReplayTV & Showstopper PVRs
