dual drive upgrade from PC laptop? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-01-2007, 08:35 PM - Thread Starter
Inextirpable's Avatar
I'm guessing one of the drives of my dual hard drive RTV has gone bad. I'd like to put in two new drives. Can i do the upgrade from a laptop PC using a USB (1.1) to IDE adapter (with hard drive power supply cord). I've read where i should be able to make this work when upgrading a single drive... but i'm not sure about a dual drive upgrade. Would i have to have two USB - IDE adapters connected at the same time to make a dual drive upgrade work? Or could i use an IDE cable that can connect to both new drives and plug that IDE cable into the USB - IDE adapter?
Thanks for any advice!
Inextirpable is offline
post #2 of 5 Old 01-01-2007, 10:27 PM
lizard_boy's Avatar
Why are you set on putting in two drives?
lizard_boy is offline
post #3 of 5 Old 01-01-2007, 10:47 PM - Thread Starter
Thanks for the response! I currently have two drives in there, so i figured that the idiot-proof method (me being a newb) would be to replace them with two new drives. Also, i was thinking about 2 300GB drives (currently 2 250GB in there). I suppose i could go with 1 500GB - supposing i wouldnt have to do anything extra going from a 2-drive to a single drive (beyond just doing a single drive upgrade patch) .
post #4 of 5 Old 01-01-2007, 10:48 PM
Creech's Avatar
Less chance of failure with just one drive. And drives are getting inexpensive.
Imagespace--Arts and Web 2.0
Musings of a Canadian Living in the United States
My Video Shorts
A Collection of Video Shorts
Creech is offline
post #5 of 5 Old 01-07-2007, 07:03 PM - Thread Starter
Follow-up... I installed a new Seagate 500GB ST3500841ACE using a USB - IDE adapter (also needed a power cord for the drive) to connect the drive to my laptop to upload the appropriate image using RTV Patch on 1/4/07. It's working great so far. Quieter than the older (western digital) drives too.
Reply ReplayTV & Showstopper PVRs
