Ethernet Port dead/ need it replaced - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 02-22-2007, 09:47 PM - Thread Starter
ejuly's Avatar
My Ethernet port is broken on my ReplayTv 4000. The 4000 is wired directly and my laptop works great when connected. I have had this machine for what seems like forever. It is a lifetime machine and I have a 4500 in another room so want the machine networked.
Has anyone ever replaced Ethernet port on a Replaytv? What are the groups suggestions?
ejuly is offline
post #2 of 6 Old 02-22-2007, 10:09 PM
gweempose's Avatar
Quoted: 32 Post(s)
Liked: 37
Mikeyboy is your man.
gweempose is offline
post #3 of 6 Old 02-22-2007, 10:15 PM
Ace987's Avatar
I don't even think you need Mikeyboy on this one. The Ethernet port is on a seperate card on the 4xxx. There are several compatible models you can pick up.
Of course, he probably stocks and sells them, so it might be easier going directly to him.
PostCount++;
ReplayTV 5080 - 00004-54831-79633
Ace987 is offline
post #4 of 6 Old 07-09-2007, 07:50 AM
tangoalpha's Avatar
Is this true for the 5040? My brother has a dead ethernet port that was fried by a spike over ethernet...killed his router and nic card on his PC too. I told my bro to connect via telephone for now.
tangoalpha is offline
post #5 of 6 Old 07-09-2007, 08:24 AM
wrlwnd's Avatar
Sorry, on the 5XXX's the lan is discrete components. However, as said earlier mikeyboy is the man for the job.
wrlwnd is offline
post #6 of 6 Old 07-09-2007, 09:29 AM
drlava's Avatar
There's a thread http://www.avsforum.com/avs-vb/showthread.php?t=870811
to post info if you get any about the 5k series ethernet port fix.
drlava is offline
Reply ReplayTV & Showstopper PVRs
