Will my Showstopper work with digital cable - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-28-2008, 11:17 PM - Thread Starter
richardkat's Avatar
My Showstopper has been used nicely with Dish for awhile. Could anyone tell me how well it would work with digital cable boxes? or should I forget it? Thanks for any information
richardkat is offline
post #2 of 6 Old 01-28-2008, 11:26 PM
Ace987's Avatar
If you got it working with DISH, you'll have no problem with digital cable, it's basically the same setup. Both use the IR blaster to change the channel, just replace the DISH receiver with a cable box.
PostCount++;
ReplayTV 5080 - 00004-54831-79633
Ace987 is offline
post #3 of 6 Old 01-29-2008, 11:50 AM - Thread Starter
richardkat's Avatar
I'm wondering if Showstoppers have the right codes. And read here somewhere they might be limited to only 100 stations.
post #4 of 6 Old 01-29-2008, 01:08 PM
arcadefreaque's Avatar
Number of stations should not be an issue, but the codes for your cable box may indeed be a problem. If it were not for some great investigative work by someone else on these forums, I would have never known the codes for my amino settop boxes - as they are not listed by replay or tivo, and the cable company had no idea what codes would work.
post count = post count + 1
arcadefreaque is offline
post #5 of 6 Old 01-29-2008, 01:45 PM
rm -rf *.*'s Avatar
When you stop and think about it, that's not really plausable.
While there are a host of problems you could have like digits being interperted twice or improper/incomplete IR codes, etc, a 100 channel limitation just doesn't make much sense.
Still no news from New Zealand.
If we ever get any, we'll be sure to let you know.
rm -rf *.* is offline
post #6 of 6 Old 01-29-2008, 11:02 PM - Thread Starter
richardkat's Avatar
Thanks for your input guys.
It looks like there is no problem with the digital boxes. All I had to do was look in the setup and found codes for Cox & Time Warner digital boxes. Also a listing for all the stations availiable pops up immediately. It is very simple compared to programming the Satellite boxes.
Sorry for spinning everyones wheels...I should have checked this first
Reply ReplayTV & Showstopper PVRs
