Missing sharp aquos screws...help? - AVS Forum
post #1 of 9 Old 03-06-2008, 05:58 AM - Thread Starter
soose95's Avatar
I purchased a Sharp Aquos TV (Model # LC-32D44U) and table mount stand. There were no screws in the kit and I'm having no luck finding a place to order them. Can anyone steer me in the right direction? Please?
thanks
soose95 is offline
post #2 of 9 Old 03-06-2008, 06:08 AM
DougRuss's Avatar
Contact the Dealer you bought it from!
DougRuss is offline
post #3 of 9 Old 03-06-2008, 02:11 PM
budk's Avatar
hardware store?... they are probably just a flat head metric screw... as long as you get the right size it won't be a problem.... measure and buy a couple of differnent screws around the size of your measurement.
Bud
There is a solution to every problem.
2nd Run Cinema - A fabric frame theater
budk is offline
post #4 of 9 Old 03-18-2008, 07:02 PM
dholmes55's Avatar
No I've been where you are dude!!!
Capped screws using allen key the size is 6mm by 20mm .
You can buy them at loews or Home depot for like .95 cents each. Sharp will charge you like 19 bucks for 8 screws
Good Luck !
dholmes55 is offline
post #5 of 9 Old 04-12-2012, 05:13 AM
davige's Avatar
This is very late (4 years) but may help someone some day. For my Sharp LC52D64U stand:
Arm to base: 4 - M6 x 35mm
TV to arm: 4 - M5 x 16mm
BTW: base model CDAI-A418WJ36 fits just as well as the original CDAI-A376WJ32 and is usually cheaper on ebay.
ydoubleun and Lou-Card-Fan like this.
davige is offline
post #6 of 9 Old 11-25-2012, 12:26 PM
lucholland's Avatar
Thanks for this post - it certainly helped me after losing some parts during a recent move!!
lucholland is offline
post #7 of 9 Old 06-28-2013, 01:03 PM
antifan's Avatar
Thanks from me too - lost the screws to the base that I haven't used for 5 years (moved a couple times too). This worked on an LC-46D64U. It's still mounted right now so I'm not 100% on the length of the screw but the diameter was correct.
http://www.homedepot.com/p/M5-0-8-x-16-mm-Zinc-Plated-Pan-Head-Phillips-Drive-Machine-Screws-3-Pieces-80138/202210110#.Uc3sAZyOBac
antifan is offline
post #8 of 9 Old 12-29-2013, 12:51 PM
Lou-Card-Fan's Avatar
This post helped me out a great deal. I am glad I found this before I went to the store and guessed. Daviage your sizes appear to work. You may have been late but it helped me.
Lou-Card-Fan is offline
post #9 of 9 Old 04-07-2014, 05:32 PM
ydoubleun's Avatar
it works fine with my LC-60LE630M too..missing the screws pack when i bought
thanks guys!!!
ydoubleun is offline
Reply Tweaks and Do-It-Yourself
User Tag List
