Add 12 volt trigger to prosound amp? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 23 Old 09-11-2008, 02:40 PM - Thread Starter
mauiguy100's Avatar
Any electronics gurus want to help me add a 12volt trigger to my berringer 2500 amp? I am looking for a way to automaticly turn it on when my AVR turns on. I'm guessing I could use a relay in place of the power switch but am worried about adding ground loop noise. Yes I know it will void my warranty but hey that's what diy is all about right?
mauiguy100 is offline
post #2 of 23 Old 09-11-2008, 06:16 PM
AV Doogie's Avatar
A simple solution is to put together an electrical outlet in a job-box with a 12 volt relay providing the power switching to the outlet. I assume that you have a useable trigger output from your AVR or preamp.
You can make this little relay controlled outlet for about $20. I can supply a schematic if you need one. Or additional information.
My Home Theater Site:
DJ-Theater
AV Doogie is offline
post #3 of 23 Old 09-11-2008, 10:48 PM - Thread Starter
mauiguy100's Avatar
Good Idea AV Doogie. Gets the job done without cracking into the brand new amp. Could you post a parts list and schematic please?
I used the link to check out your theater. Looks really nice. Those seats look comfy and the built in rack is killer.
thanks
post #4 of 23 Old 09-12-2008, 07:44 AM
Marbles_00's Avatar
http://sound.westhost.com/project118.htm
Instead of connecting it to a computer, you connectorize it to connect to your AVR. I use this in my music-server to shut the peripherals off when the computer goes into sleep mode. Works pretty good.
My web-o-information:
http://sites.google.com/site/maycreates/
Where I discuss the following projects
-DIY multi-zoning music distribution
-HTPC
-MediaPVR
-UnRAID Server
-and other projects
Marbles_00 is offline
post #5 of 23 Old 09-15-2008, 06:44 PM
AV Doogie's Avatar
thanks
I don't have an exact parts list handy... but most of the parts can be found at a local radio shack or electrical parts house.
1 - job box to house the relay and duplex outlet
1 - DPST or DPDT relay (12 volt coil with contacts rated for 125v at 15 amps)
1 - duplex outlet with ground (same as used in your house)
1 - three conductor power cord with plug (length to be determined by you)
1 - two conductor control wire (length tbd by you) this plugs into your 12V trigger from the AVR or processor. You may need a one-eighth inch phono plug if the AVR has a one-eighth inch plug attachment.
1 - soldering iron and solder
1 - a few feet of 14AWG stranded wire to connect the relay and outlet within the job box
relay.pdf 15.1689453125k . file
DJ-Theater
post #6 of 23 Old 09-17-2008, 03:21 PM
ChrisWiggles's Avatar
you could also just buy a triggered outlet too
ChrisWiggles is offline
post #7 of 23 Old 09-17-2008, 04:10 PM
AV Doogie's Avatar
Do you know of any retailers or sources for triggered outlets?
DJ-Theater
post #8 of 23 Old 09-17-2008, 04:41 PM
Marbles_00's Avatar
Yeah here's one:
http://www.shopwiki.com/detail/d=110...jumpToFirst=t/
But where's the DIY joy in that? Not to mention if you have most parts (or know someone who does), it is far cheaper to build a triggered AC outlet than buy it...$50 - $60 for one triggered outlet, or $40 in parts (including powerbar) for multiple triggered AC outlets...for future proofing.
-HTPC
-MediaPVR
-UnRAID Server
-and other projects
post #9 of 23 Old 09-18-2008, 10:28 AM
AV Doogie's Avatar
Originally Posted by Marbles_00 View Post
Yeah here's one:
I agree , but I have never seen a 'cheap' triggered unit....not that I have really looked!
DJ-Theater
post #10 of 23 Old 10-06-2008, 04:35 PM
WilliamZX11's Avatar
Quoted: 25 Post(s)
WilliamZX11 is offline
post #11 of 23 Old 02-20-2009, 01:26 AM
DarrenBarrow's Avatar
Hi
Wonderful info guys....The list of apps looks great.....and i thank u....
staffingpower dot com
sentersoftech dot com
DarrenBarrow is offline
post #12 of 23 Old 02-20-2009, 08:06 AM
duvetyne's Avatar
Use a Solid state relay with zero cross switching.
duvetyne is offline
post #13 of 23 Old 02-21-2009, 08:16 AM
AV Doogie's Avatar
Huh?
DJ-Theater
post #14 of 23 Old 02-22-2009, 08:15 AM
duvetyne's Avatar
A solid state relay is a relay that uses a Triac or inverse parallel SCR's as the switching element. Some have trigger circuits that switch the load at the zero cross, for smooth, RF free, load control.
duvetyne is offline
post #15 of 23 Old 02-22-2009, 12:37 PM
AV Doogie's Avatar
Zero crossing switching is needed in this situation because?
DJ-Theater
post #16 of 23 Old 02-23-2009, 08:52 AM
duvetyne's Avatar
Why would you want to switch at the peak?
duvetyne is offline
post #17 of 23 Old 02-23-2009, 01:18 PM
AV Doogie's Avatar
With this type of equipment....why does it matter? The inrush is manageable.
The only place we use zero cross switching is for power applications where capacitive loads are switched for power factor correction.
DJ-Theater
post #18 of 23 Old 02-23-2009, 01:19 PM
duvetyne's Avatar
We use it whenever we switch a large load, it doesn't add much to the cost, and allows the load to power up smoothly, without the burst of RF usually associated with it.
BTW, no-one said it was needed, it was suggested.
duvetyne is offline
post #19 of 23 Old 09-02-2011, 09:35 AM
KK20's Avatar
Quoted: 12 Post(s)
Reviving this thread as I built a 12v switched 20A outlet with a solid state relay.
It works, however, the amp is humming, similar to a ground loop hum. The hum actually comes from the amp, not through the speakers.
I tried a different (same model) relay with the same issue.
Do I need some transistor/capacitor or something across the 12v side or ???
All suggestions are welcome!
KK20
KK20 is online now
post #20 of 23 Old 09-03-2011, 08:08 AM
Speedskater's Avatar
Quoted: 20 Post(s)
Sounds like the "solid state" relay is doing something nasty to the AC waveform.
Sometimes it's called DC offset.
Do you have an O-scope?
What is the relay's part number?
Kevin
Speedskater is offline
post #21 of 23 Old 03-05-2012, 01:04 AM
findlaypc's Avatar
For starters, I've been lurking here for years. Haven't had a need to post, yet, because so far just searching the forums has always been able to answer my questions.
I'm adding a 12v trigger to the old Ashly FET-1000 that currently drives my subs. I've ordered a 25A solid-state relay to do the job, along with a heatsink (since it didn't add much to the cost), and it seems like a straight-forward thing to integrate it into the amplifier itself (there's lots of room inside the chassis).
My question is this: Once in awhile, I pull the Ashly out to do actual pro-sound things. And in that world, 12V triggers just don't happen: You show up, plug the amps in, turn them on at the appropriate time, and that's that. Meanwhile, at home, I really would rather have the amp (and its noisy fan, and the power draw) off when not in use, hence the 12V trigger from my AVR.
In order to do both things, I intend to use the Ashly's existing front-panel switch to bypass the SSR. Logically, it will do exactly what I want (it's just an OR gate), but in terms of practicality I'm just not sure since I've never played with SSRs before.
It seems to me that the SSR will always see either 120 or 0 volts across its output terminals, regardless. And to that end, it seems that it will be happy (ie: not catching itself on fire) in any configuration.
But I just want a second opinion before I wire the thing up.
Lexicon RV-5 AVR, Krell DVD Standard for the CDs, Ashly FET-1000 (subs), kit-built Hitmakers for mains, ancient/silly/awesome 2x2x10" Peerless subs, with EV's silly egg-shaped MTMs as surrounds and a tiny little 4" Memorex cast-Al center channel cabinet with an ancient NOS Soundstream 4" whizzer-cone running full-range. Oh, and a PS3. (And a Chromecast for special music, but nobody cares.)
findlaypc is offline
post #22 of 23 Old 03-05-2012, 08:44 AM
AV Doogie's Avatar
When you refer to the SSR (Surround Sound Reciever) output terminals, are you referring to the audio output or a set of power outlets on the rear of the SSR?
DJ-Theater
post #23 of 23 Old 03-05-2012, 08:54 AM
SAM64's Avatar
Liked: 78
He's referring to a Solid State Relay.
Yes, like any switch.
SAM64 is offline
Reply Tweaks and Do-It-Yourself
