Cable management please help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-03-2010, 10:41 PM - Thread Starter
RB951's Avatar
I need some cable raceways that are going to house a 12 guage wire and a cable for a sub. What size would be appropriate and were can I buy the most inexpensive ones. I need the raceways to have an adhesive back
RB951 is offline
post #2 of 3 Old 01-05-2010, 09:37 AM
RobG5589's Avatar
I used some from Lowes. They come in separate pieces or in kit form. The kit is a much cheaper route to go if you need all or most of the included pieces. It is plenty large enough to house two 12g and sub cables. And it sticks. I misplaced one a tad off and when trying to pull it back off it tore off the drywall so make sure of placement before removing the paper from the sticky.
RobG5589 is offline
post #3 of 3 Old 01-13-2010, 11:14 AM
Neurorad's Avatar
Quoted: 236 Post(s)
Liked: 145
What's the 12 guage wire for? 110V AC?
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
Reply Tweaks and Do-It-Yourself
