RCA connectors question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 01-15-2010, 08:52 PM - Thread Starter
geort45's Avatar
Hi!
I'm planning on using RCA connectors for a basic electronic DIY project, however since the connector is more for the AV world I thought I'd better ask here...
My plan is to substitute my computer's fan's connectors with RCA's. I just need two cables per fan so I thought it would be perfect.
My question is this: on a male RCA connector I know there's insulation between the prong and the ring, however many connectors have a metal casing and I don't see any insulation between the ring and such casing. I intend to use 12V on the prong and GROUND on the ring, but I don't know if it would be risky to touch the casing since it would be in fact touching the ring?
Thanks a lot!
geort45 is offline
post #2 of 9 Old 01-16-2010, 03:11 AM
ChrisWiggles's Avatar
If you're talking relatively normal 12v with low current it wouldn't be like dangerous unless you had a pacemaker or something. Not necessarily pleasant if it was a capable 12v power supply with some amps behind it, but not a big deal. Not sure you'd want to do that though because you could zap components in your computer with 12v and fry everything in there. Doesn't sound like a smart plan. Why not use another type of connector? Doesn't make sense to me.
ChrisWiggles is offline
post #3 of 9 Old 01-16-2010, 03:23 PM - Thread Starter
geort45's Avatar
Hi!
The fans already use 12V, but not much current (.25A tops maybe). What I intend to use is simply have a single location to connect all the fans instead of connecting them in the scattered locations of the motherboard. I'm thinking about RCA for aesthetics mainly, although I know XLR should be safer since the pins are inside and isolated from the outside.
But although RCAs have much more variety, fact is I don't like the casing to be metallic/conductive. I just have plastic RCAs so I didn't know for sure if there was some insulation between the ring and the casing so that's why I asked, but it seems there is none... so I guess I'll have to chose a plastic RCA connector or go safe with mini XLR . Only thing preventing me to choose mini XLR is that all the connectors I could get on ebay, are basically the same and kind of ugly :/
geort45 is offline
post #4 of 9 Old 01-16-2010, 04:06 PM
I don't understand what's wrong with the regular plastic fan connectors? Just use those.
post #5 of 9 Old 01-16-2010, 04:37 PM
Kal Rubinson's Avatar
Quoted: 678 Post(s)
Liked: 461
Agreed. Also, not using RCAs would preclude plugging in something inappropriate.
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #6 of 9 Old 01-16-2010, 07:07 PM - Thread Starter
geort45's Avatar
Haha no no, nothing wrong with them... the objective of this mod is aesthetics, both clean cable routing and the looks of anything I put in there... if there was no other option besides the standard fan connectors I would accept it, but since there are tons of different types of connectors I'm researching what can work and still look good
The prettier connectors I've seen are RCA so that's why ideally I'd choose them... but since they also have to be functional I can't make up my mind yet
geort45 is offline
post #7 of 9 Old 01-16-2010, 07:37 PM - Thread Starter
geort45's Avatar
Hmmmm! I think I'm gonna use some of those DC power plugs, they're kind of thin, and I bet I could fit them in a nice RCA housing by screwing them in the existing thread, since they're plastic !
geort45 is offline
post #8 of 9 Old 01-16-2010, 08:56 PM
Gizmologist's Avatar
Liked: 31
If you put RCA males on the fans, what are you building to house the females?
BTW The entire outer metal section of the RCA IS connected so everything metal including any metal cap/cover will be at ground potential.
I agree with the other guys that RCAs for DC inside a computer is NOT a good idea.
I would suggest Molex (similar to the main PSU connector but much smaller) These are totally encapsulated in nylon and are therefore safer around exposed metal contacts and components that an RCA would be.
Molex connectors are available at most any electronic parts house and Rad Shack.
Gizmologist is offline
post #9 of 9 Old 01-16-2010, 09:11 PM - Thread Starter
geort45's Avatar
Hi!
Yeah the outer metal housing was my main concern . But now I solved it, I'll just buy RCAs plug that I like and ONLY use the housing, then inside I'll just fit a DC power plug INCLUDING its plastic shielding, I have some here and they're almost the same size as the inner diameter a RCA housing would have , a little filing and it'll fit tightly!
geort45 is offline
Reply Tweaks and Do-It-Yourself
