4250HD : want polarized C7 angled plug - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 03-27-2010, 01:50 PM - Thread Starter
seandarcy's Avatar
I've got the Optimum cable STB, Explorer 4250HD. The power cable is a standard 2 prong polarized plug to a polarized C7 two pin which plugs into the STB.
The C7 is a female plug that looks like a figure 8. The polarized C7 has the bottom of the 8 squared off. See http://en.wikipedia.org/wiki/IEC_con..._C8_connectors
I have very little room behind the STB. The other plugs into the STB are HDMI and F type cable. I have right angle adapters for both of them But that doesn't help unless I can find a right angled polarized C7 adapter, or a cord with a right angled polarized C7.
I've looked at http://www.accessories4less.com and quail.com. Any suggestions?
sean
seandarcy is offline
post #2 of 4 Old 03-28-2010, 05:58 PM
ti-triodes's Avatar
Quoted: 232 Post(s)
Liked: 260
Try these guys. Also check fleabay.
http://www.mcmelectronics.com/
http://www.mouser.com/
http://www.newark.com/
OTOH, I was looking for some discrete C7 connectors that I could use with some existing power cables and I never saw a 90 degree adapter or cable in my extensive search. Sorry.
ti-triodes is offline
post #3 of 4 Old 03-30-2010, 07:21 AM
justtaint's Avatar
justtaint is offline
post #4 of 4 Old 11-15-2012, 01:37 AM
Jacan's Avatar
Im sure you already got a cable or some other solution but for people looking for this cable i found one and its cheap
http://www.stayonline.com/detail.aspx?id=11843
Jacan is offline
Reply Tweaks and Do-It-Yourself
